How can I install Parler and MeWe work on Librem 5 Linux/Purism
How can I install Parler and MeWe work on Librem 5 Linux/PureOS?
Thank you
It doesn’t look like you would be able to install either of them on the Librem 5 natively. Your best bet would probably be to use Anbox and then install the Android version.
Anbox has had some initial success running on early Librem 5 batches. It should become more polished with time.
Parler has a public-facing API (there are python bindings for it). Writing a plugin for libpurple, bitlebee, or emacs would be pretty trivial (at least to get basic functionality). I doubt you’ll get a native client provided by Parler though, too small of a customer base.
And you could of course also just use the web client.
