How Do I Adjust Camera Dev Balance
When I open Camera (Dev) there are very few places I can point the camera where the Balance “aA” doesn’t flutter between “aA” and "Af11 without having to manually adjust each setting?
AND
How do I switch between taking pictures and taking videos?
TIA,
~s
It’s the “Rec” button for video recording, next to the round camera still image shutter button. See pic: Selfie images. Yes or No? - #6 by amarok
The fluttering is the automatic setting trying to find balance. It sounds like normal behavior for camera. Touching the values and taking manual command stops that, if you want.
Yes. I know the Rec button is there. How do I just take a picture instead of recording a video?
You push the round button for picture. The app doesn’t change between image and video modes, it just has two buttons next to each other.
As I noted elsewhere, you may want to check your sound settings (source is set to “Handset - Built-in-audio” from sound settings) and the resulting video that it records sound.
Duh. :flushed:
Thanks JR-Fi
I hope they find a way to avoid such long delays of “Busy” soon.
It sure has improved in the last year though
~s
