Hello everyone.
Tell me where can I download the rom and emulate it with qemu?
To make it clear what I mean, I will give an example.
I go to the GnooBoot website and download and unzip rom => gnuboot-0.1-rc6_qemu-pc_2mb.tar.xz. Index of /gnu/gnuboot/gnuboot-0.1-rc6/roms
Next, I download the ISO of any distro, and run the command in the terminal:
Normally you would download a shell script that goes to some lengths to download the correct firmware so that you don’t brick your computer. I guess in your case you don’t care much which firmware you get. ??
You can grab a firmware file e.g. here and then unzip it. That will give you a folder, that in turn contains a .rom file and the SHA256 hash, and you can verify the integrity of the download with sha256sum -c ...
