I used a PureOS USB drive that I ordered from Purism to install PureOS latest on a 2 TB SSD drive that I installed in my new Librem 14.
While installing, I selected “swap (with hibernate)”.
“free -h” reports the swap partition size is 68Gi.
When I run “systemctl hibernate” the system appears to hibernate.
The last 5 log messages before shutdown are:
systemd[1]: Reached target Sleep.
systemd[1]: Starting Hibernate …
kernel: PM: Image not found (code -22)
wpa_supplicant[PID]: nl80211: deinit ifname=wls6 disabled_11b_rates=0
systemd-sleep[PID]: Suspending system…
When I power the computer back on, there seems to be no sign whatsoever of any attempt to resume the machine state before the hibernate.
The computer behaves as if I had shut it down rather than hibernated it.
There do not appear to be any relevant log messages after the power-on.
I have failed to understand my problem from the other topics on this forum that mention hibernation.
What do I need to do to get hibernation to work?
Why is it not sufficient that I selected the “swap (with hibernate)” option while installing?
Thanks for any help you can provide! Long live free software!
