Well, it should be obvious: Settings - Privacy - Screen Lock - off.
On my Librem 5 that has no effect, the screen keeps locking and asking me for the password.
Am I missing something?
This has not worked for me, either. Edit: Increasing screen lock interval works, actually.
Does it work when you manually switch off the screen? Can you switch it on afterwards without a password?
No. Requires password immediately. A bug that needs fixing, but not critical.
What’s the issue that is tracking this bug?
I’m not sure if it is being tracked.
It should be this one: https://source.puri.sm/Librem5/phosh/-/issues/457
Hi Amarok,
Looks like that link information is 2 years old & still /w updates.
