“Files” enables me to create a folder, but I can’t find a way to erase it.
The only way I found to erase files is to use “Usage”.
So my questions are:
- is there a way to erase folders?
- is there a more convenient way to erase a file (ie through “File” or a similar app)?
You can mark it and then use the “del” Button on the Terminal keyboard. You would have to switch the tap/double tap on files/folders behaviour in Files App though.
This is just one of the reasons I prefer nemo Files over nautilus Files: menu bar, and detailed options/actions that can actually be selected.
(nautilus context menu still has that bug that makes it disappear when releasing.)
Thanks @epinez!
For anyone who may have the same problem, here is the step by step solution:
- open “Files”;
- tap the three stripes icon, at the top right corner, then go in “Preferences”;
- set “Action to Open Items” on “Double click”, then go back ("<" icon, at the top left corner);
- select the file or the folder you want to delete by tapping on it;
- call the keyboard (icon at the very low right corner);
- tap the world icon on your keyboard, and select “Terminal”;
- tap “>_” on your keyboard;
- tap “Del”;
- the file or folder is deleted and placed in the trash of your phone.
How about just: rm filename from the terminal?
Of course, the console rocks, but Portfolio rules all over Files.
