I need to extract intergrated graphics ROM (Using Librem Mini) for GVT-D passthrough, the guide tells me to boot in non-uefi mode to be able to do that.
1. Enable non-UEFI mode in BIOS
2. Boot a livecd of your choice
3. Extract ROM
They extract it first and then change the device ID (0406) and use that ROM when passing it through. But I need to ssh into my mini after I detach i915 so I haven’t done it yet. Not very experienced and my router has some rules that blocks such connections. Lots of hassle.
On another guide I’ve read that you can actually detach it with a qemu hook right before you start the VM, so I will look into that.
