How to get Anki running on the Librem 5?
Hi,
I’m trying to get Anki running on the Librem 5. With the version from the PureStore, when I tried to synchronise I got the error message ‘Your Anki client does not support the new timezone handling yet. Please ensure your Anki is up to date’. I have now found out that this Anki version is too old. However, I can’t use the version from the Anki website for the Librem either. Are there any plans to update the version from the PureStore? Or does anyone else have any ideas?
Python wheels:
There’s also:
Thank you very much! I’ll try that out right away.
I’ve tried that too. But unfortunately that didn’t work either.
This is what worked for me on the Librem 5 with Byzantium:
I followed the steps to install Anki via PyPI/pip (mentioned by @FranklyFlawless above), but had to adjust them a bit. So this is what I did:
Install the PyQt5 packages:
sudo apt install python3-pyqt5.{qtwebengine,qtmultimedia}
Create a directory for Anki and cd into that directory:
mkdir anki
cd anki
Then run the following:
python3 -m venv --system-site-packages pyenv
pyenv/bin/pip install --upgrade pip
pyenv/bin/pip install --upgrade --pre aqt
Start Anki:
QT_QPA_PLATFORM=wayland pyenv/bin/anki
I got Anki flatpak to work on amber a few years ago; at least, it worked on some level.
I created this specifically with Anki in mind.
(I like to study foreign languages.)
That worked. Thank you very much!
Great that it worked!
If you want to upgrade Anki later, just run the following command again:
One more thing I did was to create a desktop button to start the app. I created a file ~/.local/share/applications/anki.desktop with the following content (mostly copied from here):
[Desktop Entry]
Name=Anki
Comment=An intelligent spaced-repetition memory training program
GenericName=Flashcards
Exec=env QT_QPA_PLATFORM=wayland /path/to/pyenv/bin/anki
Icon=anki
Categories=Education;Languages;KDE;Qt;
Terminal=false
Type=Application
Version=1.0
MimeType=application/x-apkg;application/x-anki;application/x-ankiaddon;
X-Purism-FormFactor=Workstation;Mobile;
Replace /path/to/pyenv/bin/anki with the actual path on your system.
You can get the app icon from here and put it in ~/.local/share/icons/.
That would have been my next question :slight_smile: thank you very much!
