Hi there,
when I try to install build dependencies, e.g., sudo apt-get build-dep emacs25, I’m informed that I need to add source URIs to sources.list. Which ones are available or recommended?
Thanks
Jens
Hi there,
Thanks
Jens
I had a sources.list with the following:
deb http://repo.puri.sm/pureos/ green main
deb-src http://repo.puri.sm/pureos/ green main
deb http://repo.puri.sm/pureos-debug/ green-debug main
and I got the same result as you, and solved by adding a line identical to the last one, but starting with deb-src instead of deb.
Also note that you need to do an apt-get update after editing before it will work.
I had only the first line, adding the second one worked for me.
Many thanks!
