After a long search, i did not find the solution in this forum and looked at other websites. Here is my compilation to get hibernation on the Librem 14 (tested on 2 devices), and probably on the Librem mini.
I can resume from hibernate in 16s with pureboot, and 10s with coreboot, with wifi autostart, so long because the resume starts with a normal boot and ends with resuming the session from swap. It is not so good as a resume on a mac or windows or deybian, but it is worth it. It really changed my UX of the Librem 14. In hibernation, I only loose, maybe, 2% in a day ! You really can forget it !
Create a swap partition (maybe the most âdifficultââ:
with a live Pureos usb stick (you should have the last version or compatible to your pureos version), start with the live version.
go to creating a login and install gparted from terminal
with gparted, resize your main partition to free enough space for your swap
create a partition
format it to âotherâ>âswapâ + parameters : starting point ânoneâ, sw, swap
MAYBE : be careful. I you add here encryption to your swap, it can be boring afterwards : My Librem 14âs have encryption. But I do not need this at the moment, and overall i did not want to type my passphrase or have to use my librem key TWICE to resume from hibernation (as far as I know we could not even use the libremkey pin to decrypt the swap partitionâŚ), so I am now so happy using the shortest way without swap encryption.
reboot
start âdisksâ to check your swap partition and get its UUID and its path
sudo swapon /dev/nvme0n1p3(replace with your own partition path) to activate the swap partition in your system -
sudo gedit /etc/fstab: add a line :UUID=fdf4-ggfgf4dfdfxxxxxxxx none swap sw 0(replace with your swap UUID) -
sudo gedit /etc/default/grub: to inform grub about your swap partition, add this line or modify it :
âGRUB_CMDLINE_LINUX_DEFAULT="quiet nosplash resume=UUID=fdf4-ggfgf4dfdfxxxxxxxxâ (replace with your swap UUID- here are some good parameters in that file, to boot fast:
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=lsb_release -i -s 2> /dev/null || echo Debian
GRUB_CMDLINE_LINUX_DEFAULT=âquiet nosplash resume=UUID=af40fa1f-e5af-4c8d-a361-f4f0a3b2aed8â
GRUB_CMDLINE_LINUX=ââ
sudo gedit /etc/initramfs-tools/conf.d/resume : create this file and add :
RESUME=UUID=fdf4-ggfgf4dfdfxxxxxxxx(replace with your swap UUID -
sudo gedit /etc/UPower/UPower.conf, replace HybridSleep at the end of the file like that :
CriticalPowerAction=Hibernate- Here your can change other power settings.
sudo update-initramfs -u -k allto update your kernels -
sudo update-grubto update your boot with grub -
change in power settings the action of the power button to trigger hibernate (should appear after you swapon)
test
with dconf (install it if needed),
- to get autoosleep after 5 minutes, and not only 15 in default settings, just change org.freedesktop.Tracker.Miner.Files initial-sleep = 5
- if you want auto hibernate instead of auto sleep, just set the âsleep-inactive-battery-typeâ to âhibernateâ
Enjoy !
