How to import Homebank data into a Libre Calc spreadsheet
Good morning everyone …Merry Christmas
Has anyone had experience with importing homebank data into a Libre Calc spreadsheet?
How would I do this? I’ve exported the Homebank register file but I don’t know where it is on my Librem 14 … also how do I now get this data into spreadsheet format?
Thanks for your help
Belerry
I think with Homebank you can export in CSV format, then can be used by LibreCalc
Thanks a whole bunch. I appreciate the suggestion. I’ll see if I can work with the CSV file to get the format I need.
Thanks agaIn
Happy NEw Year
Belerry
You’re welcome !
I hope it works for you !
Happy new Year to you too ! :partying_face:
