How to increase privacy on spy phones with your Librem5
Hello,
This tutorial and script is useful only for people who have to use a spy phone for specific apps and are motivated enough to diminish the constant privacy violation
It can also be used to check what any device with wifi is doing behind your back
Here are some advices :
  1. You should buy a “Silent pocket” Phone Faraday Sleeve (out of stock now …) / Phone Faraday Sleeve – Purism
    I got one from purism, I tested only GPS and Wifi 2.4G, but both are blocked if you close correctly the pocket (open = not blocking)
    And take the phone out of the pocket only when you really need it
  2. You should try to install LineageOS on the spy phone (if compatible), and use an alternative app store, it will be much better than the not up-to-date OS provided by default (lineageOS propose regular updates)
  3. You should put your SIM card in the Librem5, use Wi-Fi tethering to provide Internet to your SIMless spy phone
    In this post, I provide a script to ease the way to block all traffic and authorize only a whitelist of IP for your apps to work
How does it work ? it uses iptables, so you will need to use sudo to start or stop blocking
by default it will block all connection to all IP on all port coming from the tethering, so by default your spy phone cannot access anything on internet using your Librem5 wifi
So, to authorize an application YOU need to analyze which IP address the phone want to connect to when the app start or try to connect somewhere
To help you with this task, the script will configure iptable to log any attempt to any IP address on any port
So by default every attempt is logged and is visible with journalctl
I made 2 options :
./block_connections.sh live
./block_connections.sh logs
the option ‘live’ is printing any live attempt (ctrl+c to stop)
the option ‘logs’ deduplicate and print the IP addresses from the last 50 attempts, so maybe you can see only 13 IP addresses
Now you can see some IP, cool but what IP is related to your app ?
  1. you can use some web tools like abuseipdb.com or dnschecker.org/reverse-dns.php?query= to give you an hint, but sometimes it’s not giving any hint
  2. So, you can also use the command ‘host’ on your linux to check if the IP address correspond to the website of the app you use
    example :
    52.142.124.215 is not recognize with the web tools, but I know the app is using DuckDuckGo
    when I do
    host duckduckgo.com
    I can see
    duckduckgo.com has address 52.142.124.215
  3. If you didn’t find anything about the IP, you need to try many time you application and see, which IP appears again and again at every attempts, try to authorize it and see if it help or not
Ok now that we have validated 52.142.124.215 is related to duckduckgo.com
We can do 3 things :
  • Add the IP 52.142.124.215 to the ‘IP_blacklist’ variable in the script if you want it to stay blocked and disappear from the log when an attempt to this IP is made
  • Add the IP 52.142.124.215 to the ‘IP_whitelist’ variable in the script if you want it to be authorized always and disappear from the log when an attempt to this IP is made
  • Add a new profile so you can authorize or block at will any IP for your duckduckgo app
    There are examples in the script for those 3 possibilities
If you are still interested after this, then copy the following script in your Librem5
#!/bin/bash
if [ "$1" == "-h" ] || [ "$1" == "--help" ] ; then
    echo -e "Usage : script <start|stop|switch|profil> [profil_option]
OPTIONS:
  start               Start blocking - Initialise and insert the iptable chain CLIENT_WHITELIST in first position in FORWARD
  stop                Stop blocking - Remove CLIENT_WHITELIST from FORWARD
  switch              Act like 'stop' or 'start' if CLIENT_WHITELIST is in or not in FORWARD
  reset               Update iptables with the changes you mabe in IP_whitelist and/or IP_blacklist
  logs                Show the last IP adresses in the last 50 connection attempt
  live                Show the current connection attempts, ctrl+c to stop
  profil start <name> Authorize access to the IP addresses of the profil <name>
  profil stop <name>  Remove access to the IP addresses of the profil <name>
    exit 0
fi
# -------------------- init --------------------------
iptables -L FORWARD | grep -q "CLIENT_WHITELIST"
flg_is_present=$?
# -------------------- lists --------------------------
# Whitelist
IP_whitelist="192.168.1.0/24
138.68.253.24
128.140.118.223
# profil LineageOS update
profils="LINEAGE 104.26.14.42 104.26.15.42 116.202.242.188 130.225.254.116 172.67.69.209 128.112.18.21 89.102.0.150 141.70.124.1"
# profil duckduckgo
profils="${profils}
DUCK 52.142.124.215"
# profil F-DROID store
profils="${profils}
FDROID 89.149.59.178"
# Blacklist Google
IP_blacklist="
35.227.200.0
35.244.172.51
34.54.163.57
34.89.151.119
34.102.162.219
34.102.213.67
34.117.147.68
142.251.39.195
142.251.142.3
142.251.152.119
142.251.153.119
142.251.154.119
142.251.155.119
142.251.156.119
142.251.157.119
172.217.20.35
172.217.22.35
216.239.32.223
216.239.34.223
216.239.36.223
216.239.38.223
# Blacklist Facebook
IP_blacklist="${IP_blacklist}
157.240.202.14"
# Blacklist useless IP I don't need for my profils to work
# ------------------ functions -----------------------
init_chain() {
    # Test if chain exist and add if not
    iptables -L CLIENT_WHITELIST > /dev/null
    [ $? -ne 0 ] && iptables -N CLIENT_WHITELIST
    # ACCEPT Whitelist
    for IP in ${IP_whitelist} ; do
        iptables -A CLIENT_WHITELIST -d ${IP} -j ACCEPT
    done
    # DROP Blacklist
    for IP in ${IP_blacklist} ; do
       iptables -A CLIENT_WHITELIST -d ${IP} -j DROP
    done
    # Log everything else (non-whitelisted destinations)
    iptables -A CLIENT_WHITELIST -j LOG --log-prefix "CLIENT_BLOCKED: " --log-level 4
    # Drop non-whitelisted traffic
    iptables -A CLIENT_WHITELIST -j DROP
reset_chain() {
    # Flush all the rules in the chain
    iptables -F CLIENT_WHITELIST
    init_chain
start_blocking() {
    echo "- Start blocking"
    # Test if chain exist and initialize it if not
    [ $? -ne 0 ] && init_chain
    # Insert custom chain in first position in FORWARD
    iptables -I FORWARD 1 -i wlan0 -j CLIENT_WHITELIST
stop_blocking() {
    echo "- Stop blocking"
    # Determine the exact line to delete the right one, in case it's not in first position
    local line=$(iptables -L FORWARD -n --line-numbers | grep "CLIENT_WHITELIST" | awk '{print $1}')
    iptables -D FORWARD "${line}"
profil_start() {
    local PROFIL=$1
    [ "${PROFIL}" == "" ] && echo -e "\e[031mError\e[0m : Option 'profil start' must be followed by profil name" && exit 1
    local list=$(echo "${profils}" | grep "^${PROFIL} ")
    [ "${list}" == "" ] && echo -e "\e[031mError\e[0m : Profil inconnu : '${PROFIL}'" && exit 1
    local verif=$(iptables -L --line-numbers | grep "${PROFIL}")
    [ "${verif}" != "" ] && echo -e "\e[031mError\e[0m : Profil already set : '${PROFIL}'" && exit 1
    for IP in ${list} ; do
        [[ "${IP}" =~ ^[1-9] ]] && iptables -I CLIENT_WHITELIST 1 -d "${IP}" -j ACCEPT -m comment --comment "${PROFIL}"
    done
profil_stop() {
    local PROFIL=$1
    [ "${PROFIL}" == "" ] && echo -e "\e[031mError\e[0m : Option 'profil stop' must be followed by profil name" && exit 1
    echo "${profils}" | grep -q "^${PROFIL} "
    [ $? -ne 0 ] && echo -e "\e[031mError\e[0m : Profil inconnu : '${PROFIL}'" && exit 1
    local list=$(iptables -L --line-numbers | grep "ACCEPT" | grep "/\* ${PROFIL} \*/" | awk '{ print $1}' | sort -rn)
    local rule_nb
    for rule_nb in ${list} ; do
        [[ "${rule_nb}" =~ ^[1-9] ]] && iptables -D CLIENT_WHITELIST "${rule_nb}"
    done
# -------------------- main --------------------------
if [ "$1" == "start" ] ; then
    [ ${flg_is_present} -eq 0 ] && echo -e "\e[031mError\e[0m : Rules already set" && exit 1
    start_blocking
elif [ "$1" == "stop" ] ; then
    [ ${flg_is_present} -ne 0 ] && echo -e "\e[031mError\e[0m : Rules not set" && exit 1
    stop_blocking
elif [ "$1" == "switch" ] ; then
    if [ ${flg_is_present} -eq 0 ] ; then
        stop_blocking
    else
        start_blocking
    fi
elif [ "$1" == "profil" ] ; then
    if [ "$2" == "start" ] ; then
        [ ${flg_is_present} -ne 0 ] && start_blocking
        profil_start "$3"
    elif [ "$2" == "stop" ] ; then
        profil_stop "$3"
    else
        echo -e "\e[031mError\e[0m : Option profil must be followed by start or stop"
        exit 1
    fi
elif [ "$1" == "reset" ] ; then
    reset_chain
elif [ "$1" == "logs" ] ; then
    echo "- Last blocked IPs :"
    journalctl -n 50 -g "CLIENT_BLOCKED: " | awk '{ print $11 }' | cut -d'=' -f2 | sort | uniq
elif [ "$1" == "live" ] ; then
    journalctl -f -g "CLIENT_BLOCKED: "| awk '{ print $3 " " $11 }'
else
    echo -e "\e[031mError\e[0m : Missing or unknown parameter"
    exit 1
fi
#iptables -L
exit 0
make sure you a have the right to execute :
chmod u+x ./block_connections.sh
Now, hands-on work :
  • Start your tethering
  • Execute ‘sudo ./block_connections.sh start’
  • Execute ‘sudo ./block_connections.sh live’
  • Connect the spy phone to your Librem5 WiFi
  • You will probably see a lots IP address appearing
  • Stop the script with ctrl+c
  • Try to determine if you want to block or authorize those IP, and add them to ‘IP_blacklist’, ‘IP_whitelist’, or in ‘profils’
  • If you add something to ‘IP_blacklist’ or ‘IP_whitelist’, you need to do ‘sudo ./block_connections.sh reset’, it will apply your changes
  • If you add a new profile (example DUCK), you just need to execute sudo ./block_connections.sh profil start DUCK to authorize the IPs of the profil and sudo ./block_connections.sh profil stop DUCK to block those IPs again
  • Now execute sudo ./block_connections.sh live, start the application you want to authorize and try to determine if you want to block or authorize those IP
  • If you want to stop blocking you just have to execute sudo ./block_connections.sh stop, or sudo ./block_connections.sh switch
Once you have, configure everything you can disable the logs, by adding a # in front of the line :
you can also disable the 3 lines of the ‘for’ loop just before this line which handle IP_blacklist, which is useful only for reducing logs and knowing what you already disapprove
Some remarks :
  • You can enable the iptables -L at the end of the script to see every changes made to iptables after every execution
  • I put 192.168.0.0/24 in the IP_whitelist just to show you can put your own LAN if you need it, remove this if useless…, same with 138.68.253.24 (puri.sm) and 128.140.118.223 (forums.puri.sm) only here for example
  • For ease, you should SSH on your Librem5 from your computer
/!\ One last important thing : you need to execute sudo ./block_connections.sh start AFTER activating the tethering
every time AFTER you reactivate tethering : sudo ./block_connections.sh stop + sudo ./block_connections.sh start
because when you activate the tethering, it adds an iptable rule which authorize everything and is acting BEFORE the rule added by my script, so we need to put the rule of my script in first position
Feel free to criticize/copy/modify/redistribute the script
The modem goes crazy pinging about for a tower in a Faraday sack and burns off battery% though I guess it still pings away for emergency services calls even without a SIM. There is a non-root command to ignore modem etc in the phone and not have the android calling app show,
setprop gsm.radio.enabled true(or false)
then I recall it needing a reboot for the change to take hold. I am not sure exactly how much that truly affects modem though since the modem is super tightly tied into android hardware to the point that it shares RAM DMA.
I posted a few weeks ago how to BT tether from your Librem, that saves some battery on both devices. Bluetooth PAN network tethering - #4 by biketool
You can also use e.g.
whois $ip
and/or
nslookup $ip
(and really these days you are supposed to use dig instead of nslookup, specifically dig -x in this case). They may provide no useful info or they may be helpful. So they are just extra tools to investigate an IP address.
However I would have some concerns about blocking that is based on IP address - because IP addresses can change or even be completely dynamic.
So longer term I would probably look at supplementing this with DNS poisoning (like PiHole). If nothing else, logging DNS requests on the Librem 5 would show you what domain name, if any, the dodgy app looked up in order to arrive at the IP address that you now may want to block.
This is an interesting take.
Interesting! Thank you! It’d be useful to have it as an installable app for all those, like me, not so expert! I’m happy to pay it a reasonable fee (e.g.: 5-10€) instead of do manually all you written! Maybe you could develop a well, easy to use, GUI with selectors on-off (GPS, IPs,..)
Please consider it, thank you :slightly_smiling_face::folded_hands:
Other measures that may be of interest to some:
ANDROID
Tracker- blocking apps like Blokada5, TrackerControl, etc. They do DNS filtering similarly to Pi-hole, except you install one of these on the device for protection wherever you go, instead of only at home. In fact, these apps can use the same public blocklists that Pi-hole does. (It’s also possible to set up remote access to your home Pi-hole installation if you want to.)
LINUX
OpenSnitch, (demonstrated by Kyle Rankin) is an on-device application that monitors your outgoing connections and allows you to enable or block them.
It’s available in official repos, including PureOS, and of course from the terminal (package name opensnitch).
I tried OpenSnitch on the Librem 5 last week and, while usable, it’s not completely adapted to the small screen. And as you often need to react quickly to popups, I recommend temporarily disabling the internet connection immediately after installing it, so you can scale it to fit the screen better (in landscape orientation) before the series of dialog boxes start popping up. Then reconnect to the internet to start using it.
There are also VPN providers that offer DNS filtering, e.g. AirVPN, Proton VPN, and others.
Also remember that sneaky 3rd party trackers can be hiding in the 1st party domain, masquerading as native to the website.
Not to forget this: A guide on how to completely block Fb and other companies
:slight_smile:
While that is useful information, note that in the specific scenario here i.e. Android accessing the internet through the Librem 5 with the Librem 5 as a hotspot … you have the option of doing DNS filtering on the Librem 5 … and that could be slightly more robust since you never know whether Android can selectively bypass any DNS filtering app that is installed directly on the Android device.
