How to reset L5 eMMC booting to default state?
Dogwood is still supported by ongoing software updates. You just need to remember to set the right revision if you ever reflash again; other than that, you get the same software as everyone else.
Compared to Evergreen, on Dogwood you get a smaller battery, dimmer flashlight and RGB LED, elevated power consumption and a small chance of rare random lockups due to a hardware bug (which becomes a high chance of frequent lockups on images made for other revisions that don’t contain the workaround). It may also have troubles with acquiring a GPS fix.
On the plus side, the phone’s a bit shorter and lighter :wink: Its screen is a bit brighter too IIRC.
