How to run coreboot_util on offline machine?
Has anyone found an easy way to get coreboot_util ( Coreboot Firmware on Purism Librem Devices – Purism ) to work on an offline machine?
By default, it relies on internet connectivity.
it short, it can’t. It dynamically downloads everything based on device and user selection.
What exactly are you looking to do that you want to do offline?
I ended up compiling it on an online machine and transfer the binaries to an offline machine and install it there. I guess that’s what you’re supposed to, to get coreboot to an offline machine?
correct. Though you don’t need to compile it, you can simply download a pre-built binary. The script then allows you to inject the device serial and set the bootorder, after which you can flash it to the offline machine
