HOWTO enable mouse wheel scrolling for Logitech M310 on Gnome with Wayland
To enable scroll wheel functionality for a Logitech M310 on GNOME with Wayland on arm64, you must disable the device’s low-resolution scroll mode using the Solaar utility, as Wayland does not support the imwheel or xinput workarrows used in X11.
Install Solaar and run the following command to switch the mouse to high-resolution scrolling:
sudo apt install -y solaar
solaar config 1 lowres-scroll-mode false
If you do not know the device index (e.g., if you have multiple Logitech devices), use solaar show to identify the correct number. To make this setting persistent across reboots, add the command to your system’s startup applications or shell profile (e.g., ~/.bashrc or ~/.profile).
  • Why this works: The Logitech M310 defaults to a low-resolution mode that Wayland/libinput may not interpret correctly. Solaar communicates with the Logitech Unifying receiver to toggle this hardware setting.
  • Verification: You can verify the change by running solaar config 1 lowres-scroll-mode to ensure it returns false, and then testing scrolling in a Wayland session.
Hat tip to Brave search AI result
