I get no sound on phone calls
When making phone calls I cannot hear the other person. My kill switches are not set off and the settings are fine. I can listen to music and sound on videos in different apps, just not the phone app. I have contacted support 4 times with no response. Has anyone else experienced this and found a solution?
Have you tried doing an update? Did this issue happen after an update?
When you are on a call, what shows in the dropdown sound settings?
I have a similar problem, people do not hear me when I call them on a landline phone, on mobile phones they hear me. I think it started happening in the last week or two.
I had the issue occur once, and adjusting from that dropdown fixed it… I’d accidentally turned the volume down of the Handset volume mode.
@JCS will escalate your issue.
It started right after an update. I just updated again today and the problem is still there. Also, there is no sound when playing any music, website video/audio, nothing. I did check the drop down when on calls and it is set up at full volume.
The volume is set to full volume.
Thank you.
Which output device is selected?
The handset. I have tried all of them. I also do not get any sound from any media file, website, etc. This started after an update about a month ago. I have tabled the phone until I can get sound to work so I do not get on it often.
Just recently there was another thread where we troubleshooted similar issue. See if you can apply any of those hints: Audio Failure___! - #12 by Photon First thing to check would be, does sound work via headset/mic, what does sound settings say (screencap would be nice) and see what else is mentioned in the other thread.
I looked at that posting but I do not have any of that software installed. My set up is plain out of the box. Attached is a screen shot of my sound settings.
