i try vpn and is work very well. i use kde but with the command of the configuration is work.
compliments
I don’t want to offense you but I don’t understand what you are trying to say here, can you please re-work your message.
understand your message. I wanted to say that the VPN configuration was simple even using the terminal because I use kde. The connection is fast and stable. I bought the VPN as a way to contribute to the Purism as I also bought the Librem5.
