Idiotically removed kexec entry from crypttabs
How do I go about redoing my crypttabs? I had accidentally removed data I did not want to (by listening to AI) and removed the whole Kexec line from /etc/crypttabs. As a result, if restricted boot is used, the system will not boot. I have to enable PureBoot Basic mode (which I do not want to use) I want to verify with my Librem Key at boot. Right now I am backing up my system to another drive just in case my recourse is to reinstall. But I want to avoid a reinstall if at all possible. Which, the original goal was to enable the use of a Yubikey for LUKS 2FA (but I failed to enter thebpassword properly and AI had told me to remove the kexec entry as a fix to prevent issues). Also, after this I had noticed nvme0n1p1 was unrecognized by the system (which may or may not be related to this (or be something I never noticed)).
I would restore from backup, hopefully selectively but otherwise wholesale.
I managed to get it booted for now and am currently backing up data. I’ll just have to reinstall and restore if I can’t easily fix the missing kexec lines.
