Hi guys.
I read a bunch online about how to import contacts from android to L5 and there is a lot of noise out there. Here is how it is done, super easy:
1) Export contacts on android to VCF file format.
Details: VCF is just a text file with formatted text structured in a specific way.
2) Transfer VCF file to your L5.
Details: You can email it to your self, SCP it, mount your file system over SSHFS, etc., tons of ways to do it.
3) Insert a new line after each END:VCARD line.
Android formats the VCF files like this:
BEGIN:VCARD
VERSION:2.1
N:Firstname;Lastname;;;
FN:Firstname Lastname
TEL;CELL:1-555-555-5555
ORG:Company
END:VCARD
BEGIN:VCARD
VERSION:2.1
ORG:Company
END:VCARD
BEGIN:VCARD
VERSION:2.1
ORG:Company
END:VCARD
It needs to be formatted like this:
BEGIN:VCARD
VERSION:2.1
ORG:Company
END:VCARD
BEGIN:VCARD
VERSION:2.1
ORG:Company
END:VCARD
BEGIN:VCARD
VERSION:2.1
ORG:Company
END:VCARD
Any text editor should let you search / replace the new line quickly after the END:VCARD part.
4) Use syncevolution program to import the contacts file.
Details:
a) Install syncevolution with apt.
b) The following command will import it into the default contacts database: syncevolution --import contacts.vcf backend=evolution-contacts database=Personal
c) Review the docs on https://syncevolution.org/ on how to use syncevolution properly, especially if you have some custom contacts configuration.
Hopefully this helps some noobs trying to make the transition.
