Innacurate battery life reading
I have a Librem 15 v3 with Devuan ASCII 2.0 as my OS (running XFCE desktop environment). I notice that I get erratic battery life readings. If I leave it connected to AC power until 100% charge is displayed, it immediately goes to 97% once the cable is disconnected. Sometimes it will say that the battery is fully charged despite showing only 97%. The results from upower -d are displayed below:
With AC cable connected:
upower -d
Device: /org/freedesktop/UPower/devices/line_power_AC
native-path: AC
power supply: yes
updated: Sun 18 Aug 2019 10:53:54 PM EDT (367 seconds ago)
has history: no
has statistics: no
line-power
online: yes
Device: /org/freedesktop/UPower/devices/battery_BAT
native-path: BAT
vendor: TPS
model: S10
power supply: yes
updated: Sun 18 Aug 2019 10:57:43 PM EDT (138 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: fully-charged
energy: 53.9904 Wh
energy-empty: 0 Wh
energy-full: 53.9904 Wh
energy-full-design: 48.84 Wh
energy-rate: 9.435 W
voltage: 12.368 V
percentage: 100%
capacity: 100%
technology: lithium-ion
Daemon:
daemon-version: 0.9.23
can-suspend: yes
can-hibernate: yes
on-battery: no
on-low-battery: no
lid-is-closed: no
lid-is-present: yes
is-docked: no
A few seconds later with cable disconnected (Now shows 95%):
upower -d
native-path: AC
power supply: yes
updated: Sun 18 Aug 2019 11:01:43 PM EDT (5 seconds ago)
has history: no
has statistics: no
line-power
online: no
native-path: BAT
vendor: TPS
model: S10
power supply: yes
updated: Sun 18 Aug 2019 11:01:47 PM EDT (1 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
energy: 51.4374 Wh
energy-empty: 0 Wh
voltage: 12.258 V
time to empty: 5.5 hours
percentage: 95%
capacity: 100%
History (charge):
1566183605 95.000 discharging
Daemon:
can-suspend: yes
can-hibernate: yes
on-battery: yes
on-low-battery: no
lid-is-closed: no
lid-is-present: yes
is-docked: no
Any ideas on what is going on here and what the possible solution may be? I assume there is some miscommunication between the battery/charge controller and the OS. When running on battery power alone it also seems to lose capacity much faster than I would expect (based on the tray icon).
How were things working before you replaced the OS and desktop?
I’ve been using Devuan since the 1st week or so of owning the machine and I don’t recall if the issue was present during the short time I tested PureOS. I have owned the laptop for almost a year now but 1st started noticing this a couple of months ago. To be honest I never paid close attention to the battery monitor in the tray icon since I mostly use the machine connected to AC power. It’s possible that it has been doing it from the beginning. At first I thought the machine was somehow draining the battery even when turned off, but the erratic readings when powered on makes me think it is a communication issue. I will do some testing with a live usb image of other distros to see if it is OS specific.
