I would like to install the open source genealogy system, GRAMPS. I know it is available from the Debian repositories. However I don’t know how to direct APT to the correct repository. Therefore I am asking for directions. Thanks
Looks like GRAMPS is in the repos (don’t download it from this link). You can install it via apt in the terminal Tilix:
sudo apt install gramps
This should work. If it doesn’t try doing the following:
sudo apt update && sudo apt upgrade
Thank you. It worked perfectly! You have made an old man very happy!
