Hi,
I am looking for a long-overdue replacement for my Macbook Pro laptop, and have been looking at Librem 15 for a while now. I am looking for a Linux-based laptop that would be a great companion for the years to come. I work professionally as a developer and do a lot of (mostly) web-based application coding, web browsing, some minor-ish graphic design and generic communication on my laptop. What really caught my eye in Librem 15 was the sleek-looking design, security-features, kill switches and that it at least gives a picture of being a great workhorse laptop. If you have the Librem 15 and would like to share some answers to my questions below, it would be much appreciated!
Is Librem and PureOS suitable for a novice Linux user? I have used Linux every now and then (mostly Ubuntu on and off during the last 10-15 years or so). I also know some basic command line and seem to get by just fine by Googling or looking at man pages to find what I need. What I donāt know so much about is the architectural design of Linux and what happens under the hood, but am learning it bit by bit. I am also a programmer with some knowledge in languages like C and C++, but really just scratching the surface compared to my JavaScript-abilities. Do you think I could get by with PureOS and Librem during my novice-phase? What I find problematic sometimes is building software on my Ubuntu, and have a vague knowledge of the autoconf package building process. Usually if I run into problems not caused by missing dependencies, Google is my only option. Do I have enough Linux-ability to use PureOS and/or Librem, or should I first learn more Linux and then come back?
Does the Librem and PureOS fit āheavy dutyā-use as my main workstation? Is it stable enough, and is the hardware durable enough? I canāt lose days upon days of work time on debugging and fixing my OS. I am okay with having to do some extra configuring (compared to say, MacOS) on initial installation and getting-used-to-it -phase, but once I get rolling I want to keep on rolling. Am I looking at the right laptop?
Does the Librem 15 fit a touchpad-lover? I am a die hard fan of the touchpad, and use it a lot, including when I do graphic design work. What I appreciate in Macbook+MacOS (god itās painful to configure the touchpad on Macbook+Ubuntuā¦) is the perfect feeling of the touchpad and itās responsiveness. How does the Librem 15 touchpad compare? It surely looks and sounds good, but how is it in real life?
How well is the Librem 15 + PureOS configured out-of-the-box? How well are the hardware configured with the OS altogether? How much troubleshooting I have to go through to get the basic setup running? I read somewhere on the forum that some people received their laptops with a broken OS installation and see a few threads on hardware/software issues with the Librem 15. Whatās the truth behind this? While I really, really want to support a beautiful idea like the Librem, I just canāt invest 2000 bucks of company money on a laptop that is average-at-best, including the onboarding-phase. I know I am not going to get the fine-tuned installation process of a MacOS+Macbook and I understand that there might be some additional configuring afterwards, which is fine. What worries me is that I get a sub-par laptop for the price of a great one, and while I appreciate security and privacy, I canāt work without a great laptop.
Do you use the Librem 15 as your main workhorse? What laptops have you used before and which OS? How would you rate the Librem, say in a score of 1-5?
Are there big limitations on software I can (without a hassle) install to PureOS / Librem? I am a bit unsure about how PureOS works, are general open source software available or just a curated portion of it? For example, I absolutely love Atom for coding, can I build and run it on PureOS?
Letās talk keyboard. I know I will be receiving a laptop with a keyboard layout different from what Iāve gotten used to (Swedish / Finnish layout). Is it a problem to just reconfigure the mapping? I am okay with the physical keys being what they are
How well is the hardware built to last high and low temperatures and humid weather? I am traveling a bit in both cold to very cold and warm to very hot and humid countries. What worries me especially is hot and humid weather (think jungle or rain season in some countries), but also cold sub-or-close-to-zero weather conditions and usage. I am not talking about covering the laptop with snow or soaking it in water, but just general outdoor usage in non-optimal weather.
If you honestly think the Librem is not for me, do you have a suggestion on what to look for? I am fine running Ubuntu on a Macbook, but what would you suggest as a easy landing to the Linux world in the form of a pre-configured laptop made for heavy duty use?
EDIT 10. One more, about updates. How does the update process work in general? Letās say the worldās most horrible vulnerability is found from something in somewhere that also happens to run on the Librem+PureOS, what do I do? I am guessing there is no magic button to update, but am hoping that it does not mean I have to compile my own kernel to install a critical update?
Thanks for your time and answers in advance! Librem 15 surely looks great and sounds very intriguing. I hope you could shed some light on my worries
EDIT: Added questions⦠I canāt do waterfall even when listing questions it seems.
