Is reportbug adapted to PureOS?
Hello. :slightly_smiling_face:
I use PureOS.
I have problem with Xorg (segmentation fault cca 1 per day).
I sometimes used program with name reportbug in Debian.
Is reportbug package adjusted to correctly reporting bugs of PureOS (i.e. to properly send information to tracker.PureOS.net)?
I am asking, because in manual in PureOS version, there is written:
DESCRIPTION
reportbug is primarily designed to report bugs in the Debian distribution;
by default, it creates an email to the Debian bug tracking system at submit(AT)bugs.debian.org with information about the bug you’ve found, and makes a carbon copy of the report for you as well.
