The Brave browser on librem 5 is insanely fast compared to firefox but its not mobile friendly. Webpages are tailored for Desktop mode . Is it possible to make it more mobile tailored like in firefox configuration ?
I have not looked into this for Brave specifically, but for Chromium the issue is, that you can’t change important the UI without recompiling the entire browser, which makes the whole process a lot more involved than it is with mobile-config-firefox and its forks, as you can’t just try stuff, test it and iterate fast. That said, if the Brave Team were interested, it’s not impossible to accomplish.
If your main issue is loading mobile friendly webpages, an extension for User Agent changing should be able to do the job.
it worked ! I used a user agent switcher extension. Thanks for your help!
