have qubes-os installed on a v3 (v2?) librem 13. how do you right click? can you? just got it, so its still in return period.
would it have really been bad to throw in a couple click buttons?
It is up to what qubes sports. Trying taking with two fingers for a right click.
tried it. didnt work in pureos either.
turns out its the lower right corner. nothing in the touch pad config mention this in xfce (qubes) or gnome (pureos)
Did you try tapping on the track pad at the bottom right corner?
Hardware wise it is capable so if it is not working it is a software issue, and a setting. Have you tried looking at qubes’ mouse settings?
I believe this is in gnome tweaks under pureos.
