Issues with Boot Sequence
I’m very new to linux and pureos. I was having issues with software updates, getting an unmet dependencies error message. After reviewing forum suggestions I ran the following:
sudo apt update
sudo apt upgrade
then
sudo apt autoremove
sudo reboot
Now with every boot - it says the list of boot entries has changed and to set a new default. I’m still able to get to my “profile”- but I’m concerned that I may have done something that isn’t good regarding the setup structure.
Any advise, information, or suggestions welcome.
Thank you.
the list of boot entries changed likely because of a kernel update. You need to do what it says - select a new default from the list (likely the top entry) and then sign it as the new default using your Librem Key when prompted
@MrChromebox
Thank you for your reply. Unfortunately, I’ve done this several times (multiple reboots), yet it continues through the same sequence request.
what’s the exact error / list of files it thinks are changed?
