intel thought it would be a good idea to expose jtag over usb3 on their newer laptops. is puri.sm going to skip these series or otherwise mitigate the issue?
all that is required is that the DCI interface is enabled
Possible way of mitigation: coletely disable DCI on BIOS level (without exposing anything to a user), but this would require custom BIOS implementation like Coreboot.
to clarify, on some systems, hopefully not any of purisms, the default state is on, and the bios just turns it off. but, in these cases, you can use dci to prevent the bios from turning it off.
thats how it sounded. this part of architecture is new to me and i had to keep pausing the video to look up what they were talking about.
