Keep Wifi Active when PureOS is Locked/Asleep
Hello,
I have a need of keeping my Wifi active while my Librem15v4 is asleep.
Is there a way to configure the wireless interface to remain active while PureOS goes to sleep?
Thanks!
Depends what “asleep” means.
I can’t answer for PureOS but on Ubuntu under Settings / Power there is an option for “Wi-Fi can be turned off to save power”, which evidently you want to be “no”.
Upon toggling the switch (on/off) for Wi-fi under the Power Saving menu in the Power Settings, PureOS activates airplane mode.
Sorry, you are right, that setting doesn’t do what I thought it did.
Ok, I think what I actually want to do is prevent the laptop from going to sleep after it has been locked.
I see I can control this in the Power settings.
That should be easier.
Yes. That is what I needed to do.
