Not syncing: No working init found. Try passing init= option to kernel. See Linux Documentatio/init.txt fot guidance.
I updated my system a few weeks ago, using apt-get update && apt-get upgrade
, because the GUI updater was not reacting when I clicked upgrade system buttons. The apt-get upgrade
failed, because the mkinit… command (can’t recall) was not able to locate busybox. I looked over the script and noticed that the env var BUSYBOXDIR
was empty, so I set it (maybe to / or some other path, which allowed it to find busybox). The upgrade finally worked. But now I’ve rebooted and I cannot bring up the machine. I have the disk attached to my qnap nas. What should I do next, to fix this issue?
