Keyboard light,volume up&down ,screen brightness key
Hello family ,
I recently update my Librem 15 Laptop,I did fill upgrade and after this was done i noticed that some things are not working like before . Keyboard light,volume up&down ,screen brightness key Are not working for me again.
Is there anything i can do to sort this ? .somebody come to my aid pls .thanks
Contact Purism:
Did you do a full backup before the upgrade? If so, restoring the backup will, if nothing else, confirm whether there is a regression in the software.
It may help to identify what software you were running before the upgrade and what software you are running after the upgrade and how the upgrade was done (in place v. reinstall from scratch).
No I didn’t backup anything because I have nothing on it ,it’s just a new laptop I barely use it at all .i have it like 2years now .its running poreOs
I used sudo apt full-upgrade
