Keyboard/mouse, usb controllers and drives
these questions are for both models
are the internal keyboard/touchpad on a ps2 or usb bus? if usb, do they have their own controller, separate from the external ports? do one of the slow external usb ports have its own controller? (so you could assign that to dom0 for a trusted external mouse)
is there a switch or easy way to physically disable one of the internal drives? for example if you want both drives to mutually distrust each other, or one that you dont want the other reading?
Hi pixel,
On a Librem 13:
Both are on a PS/2 bus:
root@brigitte:~# cat /sys/bus/serio/devices/serio0/input/input0/name
AT Translated Set 2 keyboard
root@brigitte:~# cat /sys/bus/serio/devices/serio1/input/input2/name
ImPS/2 Generic Wheel Mouse
There is no switch, but if you really need a hardware solution I guess you can quite easily rework both the M.2 and the SATA connectors to route the power path via the switches on the hinge, for example.
Cheers
дядя Вова
Thanks! are one of the usb ports on its own controller? id like to have an external mouse in dom0
Hi, sorry for the delay.
Nope. With a mouse connected to USB port on the left side:
root@brigitte:~# lsusb -t /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/11p, 480M |__ Port 1: Dev 12, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M |__ Port 4: Dev 2, If 0, Class=Wireless, Driver=btusb, 12M |__ Port 4: Dev 2, If 1, Class=Wireless, Driver=btusb, 12M |__ Port 5: Dev 3, If 0, Class=Video, Driver=uvcvideo, 480M |__ Port 5: Dev 3, If 1, Class=Video, Driver=uvcvideo, 480M
On the right side:
root@brigitte:~# lsusb -t /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/11p, 480M |__ Port 2: Dev 13, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M |__ Port 4: Dev 2, If 0, Class=Wireless, Driver=btusb, 12M |__ Port 4: Dev 2, If 1, Class=Wireless, Driver=btusb, 12M |__ Port 5: Dev 3, If 0, Class=Video, Driver=uvcvideo, 480M |__ Port 5: Dev 3, If 1, Class=Video, Driver=uvcvideo, 480M
I guess you can do that with an external hub anyway. Please note, though, that I’m by no means trying to encourage you to get a Librem laptop!
Cheers
дядя Вова
