L14 and ultrawide screens
Does anyone have any experience with ultrawide screens and the L14. I am trying to decide whether it is better to buy two 21" screens or an ultra-wide screen. If ultra-wide, what ultra-wide screens are optimal? I am using the latest version of PureOS.
Thanks!
It depends on your use case.
I am not a gamer. I use it mostly for writing, reading or coding. But I would like to have the ability to have at least two windows open side by side so I can compare texts, codes, etc.
You will need to determine your preferred resolution, refresh rate, and bit depth against the preferred interface’s bandwidth specifications. HDMI 2.0 supports up to 18 Gbps, while DisplayPort 1.2 supports up to 21.6 Gbps.
According to the L14 specs, the HDMI and USB C support up to 10Gbps and 60hz max
