There are a number of tools/utilities available (pre-installed) on the phone that could be used to answer most if not all the recent questions being asked.
For example (pactl, pa-info, aplay and arecord)…
pactl list sources this will list all pulseaudio sources with a lot of detail, perhaps of interest to those guessing icons and their meaning would be the “device.icon_name” parameter for each source. pactl list short sources this is the same as previous but is an abbreviated/short form for when the previous is a bit information overload.
pactl list sinks same as above but for pulseaudio sinks.
aplay -l this lists all playback devices, integrated or not, all devices are “cards”.
aplay -L provides a bit more information on the capabilities of the various devices/cards.
aplay provides information on playback devices, arecord (arecord -l, arecord -L) provides the same information for capture devices/cards.
pa-info dumps the entire state of the pulseaudio server, typically way more info than anybody really needs.
These are just a small subset of tools/commands available.
Some sample outputs…
aplay -l, cards 0 and 1 are internal/integrated, card 2 is the modem, cards 3 and 4 are USB devices/cards
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: imxaudiohdmi [imx-audio-hdmi], device 0: i.MX HDMI i2s-hifi-0 [i.MX HDMI i2s-hifi-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: L5 [Librem 5], device 0: 308b0000.sai-wm8962 wm8962-0 [308b0000.sai-wm8962 wm8962-0]
Subdevices: 1/1
card 2: Modem [Modem], device 0: 30030000.sai-bm818 bm818-0 [30030000.sai-bm818 bm818-0]
Subdevices: 1/1
card 3: RU6 [Cayin RU6], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 4: Amplifier [THX Onyx USB Amplifier], device 0: USB Audio [USB Audio]
Subdevices: 1/1
aplay -L
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default
Playback/recording through the PulseAudio sound server
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
hw:CARD=imxaudiohdmi,DEV=0
imx-audio-hdmi, i.MX HDMI i2s-hifi-0
Direct hardware device without any conversions
plughw:CARD=imxaudiohdmi,DEV=0
Hardware device with all software conversions
sysdefault:CARD=imxaudiohdmi
Default Audio Device
dmix:CARD=imxaudiohdmi,DEV=0
Direct sample mixing device
usbstream:CARD=imxaudiohdmi
imx-audio-hdmi
USB Stream Output
hw:CARD=L5,DEV=0
Librem 5, 308b0000.sai-wm8962 wm8962-0
plughw:CARD=L5,DEV=0
sysdefault:CARD=L5
dmix:CARD=L5,DEV=0
usbstream:CARD=L5
Librem 5
USB Stream Output
hw:CARD=Modem,DEV=0
Modem, 30030000.sai-bm818 bm818-0
plughw:CARD=Modem,DEV=0
sysdefault:CARD=Modem
dmix:CARD=Modem,DEV=0
usbstream:CARD=Modem
Modem
USB Stream Output
hw:CARD=RU6,DEV=0
Cayin RU6, USB Audio
plughw:CARD=RU6,DEV=0
sysdefault:CARD=RU6
front:CARD=RU6,DEV=0
Front output / input
surround21:CARD=RU6,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=RU6,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=RU6,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=RU6,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=RU6,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=RU6,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=RU6,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=RU6,DEV=0
usbstream:CARD=RU6
Cayin RU6
USB Stream Output
hw:CARD=Amplifier,DEV=0
THX Onyx USB Amplifier, USB Audio
plughw:CARD=Amplifier,DEV=0
sysdefault:CARD=Amplifier
front:CARD=Amplifier,DEV=0
surround21:CARD=Amplifier,DEV=0
surround40:CARD=Amplifier,DEV=0
surround41:CARD=Amplifier,DEV=0
surround50:CARD=Amplifier,DEV=0
surround51:CARD=Amplifier,DEV=0
surround71:CARD=Amplifier,DEV=0
iec958:CARD=Amplifier,DEV=0
dmix:CARD=Amplifier,DEV=0
usbstream:CARD=Amplifier
USB Stream Output
pactl list sources
pactl list sources
Source #0
State: SUSPENDED
Description: Monitor of Built-in Audio Stereo
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 6
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor of Sink: alsa_output.platform-sound-hdmi.stereo-fallback
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Built-in Audio Stereo"
device.class = "monitor"
alsa.card = "0"
alsa.card_name = "imx-audio-hdmi"
alsa.long_card_name = "imx-audio-hdmi"
alsa.driver_name = "snd_soc_imx_hdmi"
device.bus_path = "platform-sound-hdmi"
sysfs.path = "/devices/platform/sound-hdmi/sound/card0"
device.form_factor = "internal"
device.string = "0"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card"
Formats:
pcm
Source #1
State: SUSPENDED
Description: Monitor of Built-in Audio Headphones + Speaker + Handset
Owner Module: 7
Mute: no
balance 0.00
Monitor of Sink: alsa_output.platform-sound.HiFi__hw_L5__sink
Properties:
device.description = "Monitor of Built-in Audio Headphones + Speaker + Handset"
alsa.card = "1"
alsa.card_name = "Librem 5"
alsa.long_card_name = "Librem 5"
alsa.driver_name = "snd_soc_simple_card"
device.bus_path = "platform-sound"
sysfs.path = "/devices/platform/sound/sound/card1"
device.string = "1"
Formats:
pcm
Source #2
State: SUSPENDED
Description: Built-in Audio Headset Microphone + Stereo Microphones + Handset Microphone
Owner Module: 7
Mute: no
Volume: front-left: 26852 / 41% / -23.25 dB, front-right: 26852 / 41% / -23.25 dB
balance 0.00
Base Volume: 26852 / 41% / -23.25 dB
Monitor of Sink: n/a
Flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "308b0000.sai-wm8962 wm8962-0"
alsa.id = "308b0000.sai-wm8962 wm8962-0"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
device.string = "hw:L5"
device.buffering.buffer_size = "8448"
device.buffering.fragment_size = "4224"
device.access_mode = "mmap"
device.profile.name = "HiFi: hw:L5: source"
device.profile.description = "Headset Microphone + Stereo Microphones + Handset Microphone"
alsa.mixer_device = "hw:L5"
device.description = "Built-in Audio Headset Microphone + Stereo Microphones + Handset Microphone"
filter.apply.echo-cancel.parameters = "channels=1 use_master_format=yes aec_args=\"analog_gain_control=0\""
Ports:
[In] Headset: Headset Microphone (type: Headset, priority: 1000, not available)
[In] Mic: Stereo Microphones (type: Mic, priority: 100, availability unknown)
[In] Handset2: Handset Microphone (type: Handset, priority: 500, availability unknown)
Active Port: [In] Handset2
Formats:
pcm
Source #3
State: SUSPENDED
Description: Monitor of Modem Stereo
Owner Module: 21
Mute: no
balance 0.00
Monitor of Sink: alsa_output.platform-sound-wwan.stereo-fallback
Properties:
device.description = "Monitor of Modem Stereo"
alsa.card = "2"
alsa.card_name = "Modem"
alsa.long_card_name = "Modem"
device.bus_path = "platform-sound-wwan"
sysfs.path = "/devices/platform/sound-wwan/sound/card2"
device.string = "Modem"
device.icon_name = "modem"
Formats:
pcm
Source #4
State: SUSPENDED
Description: Modem Stereo
Owner Module: 21
Mute: no
Volume: front-left: 98304 / 150% / 10.57 dB, front-right: 98304 / 150% / 10.57 dB
balance 0.00
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
device.api = "alsa"
alsa.name = "30030000.sai-bm818 bm818-0"
alsa.id = "30030000.sai-bm818 bm818-0"
alsa.device = "0"
alsa.card = "2"
device.string = "hw:Modem"
device.profile.name = "stereo-fallback"
device.profile.description = "Stereo"
device.description = "Modem Stereo"
Ports:
analog-input: Analog Input (type: Analog, priority: 10000, availability unknown)
Active Port: analog-input
Formats:
pcm
Source #5
State: SUSPENDED
Description: Monitor of Cayin RU6 Analog Stereo
Owner Module: 28
Mute: no
balance 0.00
Monitor of Sink: alsa_output.usb-Cayin_Cayin_RU6_Cayin_RU6-00.analog-stereo
Properties:
device.description = "Monitor of Cayin RU6 Analog Stereo"
alsa.card = "3"
alsa.card_name = "Cayin RU6"
alsa.long_card_name = "Cayin Cayin RU6 at usb-xhci-hcd.5.auto-1.4.1, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "platform-xhci-hcd.5.auto-usb-0:1.4.1:1.0"
sysfs.path = "/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb3/3-1/3-1.4/3-1.4.1/3-1.4.1:1.0/sound/card3"
udev.id = "usb-Cayin_Cayin_RU6_Cayin_RU6-00"
device.bus = "usb"
device.vendor.id = "2d87"
device.vendor.name = "Cayin"
device.product.id = "c001"
device.product.name = "Cayin RU6"
device.serial = "Cayin_Cayin_RU6_Cayin_RU6"
device.string = "3"
device.icon_name = "audio-card-usb"
Formats:
pcm
Source #6
State: SUSPENDED
Description: Monitor of THX Onyx USB Amplifier Analog Stereo
Owner Module: 29
Mute: no
balance 0.00
Monitor of Sink: alsa_output.usb-THX_Ltd._THX_Onyx_USB_Amplifier_0-00.analog-stereo
Properties:
device.description = "Monitor of THX Onyx USB Amplifier Analog Stereo"
alsa.card = "4"
alsa.card_name = "THX Onyx USB Amplifier"
alsa.long_card_name = "THX Ltd. THX Onyx USB Amplifier at usb-xhci-hcd.5.auto-1.1, high speed"
device.bus_path = "platform-xhci-hcd.5.auto-usb-0:1.1:1.0"
sysfs.path = "/devices/platform/soc@0/38100000.usb/xhci-hcd.5.auto/usb3/3-1/3-1.1/3-1.1:1.0/sound/card4"
udev.id = "usb-THX_Ltd._THX_Onyx_USB_Amplifier_0-00"
device.bus = "usb"
device.vendor.id = "3378"
device.vendor.name = "THX Ltd."
device.product.id = "03e9"
device.product.name = "THX Onyx USB Amplifier"
device.serial = "THX_Ltd._THX_Onyx_USB_Amplifier_0"
device.string = "4"
Formats:
pcm
Source #7
State: SUSPENDED
Description: THX Onyx USB Amplifier Mono
Sample Specification: s16le 1ch 48000Hz
Channel Map: mono
Owner Module: 29
Mute: no
Volume: mono: 65536 / 100% / 0.00 dB
balance 0.00
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
device.api = "alsa"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.device = "0"
alsa.card = "4"
device.bus = "usb"
device.string = "hw:4"
device.buffering.buffer_size = "192000"
device.buffering.fragment_size = "96000"
device.access_mode = "mmap+timer"
device.profile.name = "mono-fallback"
device.profile.description = "Mono"
device.description = "THX Onyx USB Amplifier Mono"
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, availability unknown)
Active Port: analog-input-mic
Formats:
pcm
