The L5 connects to external monitor
the icon for two displays is on and the L5 recognizes that two displays are used
But the external Samsung monitor just turns black and then live again and then black and live with lines and slightly flickering etc
I would look in the journal to see whether it gives an indication of what the issue is.
Model of monitor and/or specification? (resolution, frame rate)
Type of connection that you are attempting to use? e.g. is this a direct USB-C to USB-C connection? or is there a USB-C to HDMI adapter involved? or a dock involved? or?
For direct USB-C to USB-C it’s always worth trying the cable in the 4 possible orientations.
Than you for your suggestions.
This happens with two different docks and with both docks it sometimes works and sometimes doesn’tt and I just can’t see a particular reason why it works for few moments or few minutes and then doesn’t work at all?
