After todays update I am not able to make or receive any calls.
When I try to call it tries to connect but then it hangs up.
I I try to call L5 with another phone it appears to be busy.
It also frequently shows only 2G and not 4G as it used to show. And the 2G has typically the exclamation mark.
This is kind of urgent. I need to use the phone. Anyone else experiencing the same issues?
If not I need to downgrade. But how to do it. I do not remember what it installed today. Running ls -ltr in the package folder it seems that probably it installed these:
-rw-r--r-- 1 root root 17M May 20 03:05 linux-image-6.2.0-1-librem5_6.2.13pureos2_arm64.deb
-rw-r--r-- 1 root root 1.3M May 20 03:05 linux-libc-dev_6.2.13pureos2_arm64.deb
-rw-r--r-- 1 root root 29K May 20 03:05 linux-image-librem5_6.2.13pureos2_arm64.deb
-rw-r--r-- 1 root root 166K May 20 11:49 libkpathsea6_2020.20200327.54578-7+deb11u1_arm64.deb
-rw-r--r-- 1 root root 79K May 20 11:49 libsynctex2_2020.20200327.54578-7+deb11u1_arm64.deb
-rw-r--r-- 1 root root 73K May 21 17:49 libfontembed1_1.28.7-1+deb11u2_arm64.deb
-rw-r--r-- 1 root root 134K May 21 17:49 libcupsfilters1_1.28.7-1+deb11u2_arm64.deb
-rw-r--r-- 1 root root 198K May 21 17:49 cups-filters-core-drivers_1.28.7-1+deb11u2_arm64.deb
-rw-r--r-- 1 root root 561K May 21 17:49 cups-filters_1.28.7-1+deb11u2_arm64.deb
-rw-r--r-- 1 root root 152K May 21 17:49 cups-browsed_1.28.7-1+deb11u2_arm64.deb
-rw-r--r-- 1 root root 95K May 21 23:49 libwebpmux3_0.6.1-2.1+deb11u1_arm64.deb
-rw-r--r-- 1 root root 86K May 21 23:49 libwebpdemux2_0.6.1-2.1+deb11u1_arm64.deb
-rw-r--r-- 1 root root 238K May 21 23:49 libwebp6_0.6.1-2.1+deb11u1_arm64.deb
What can I do?
