Interesting, may be related, but also may not. My phone(s) have kept ringing also with incoming calls from known contacts.
I have gnome-call vers 44~alpha.0-1pureos1 installed.
Mine does the same, (1) not picking up when receiving an incoming call from my contacts and (2) forever ringing, despite toggling the cellular hardware kill switch to kill the cellular modem. To get the ringing to stop, I reboot the L5 from the pull-down menu. I have VoLTE enabled, in the USA (T-Mobile). As it stands, receiving calls on my L5 is now broken.
I’m using 44~alpha.0-1pureos1 and my phone has been working great. For both recieving and making calls. I am using the VoLTE enabled though. not sure if that matters.
44-alpha.0 has been iffy for me as well, last night my wife was trying to call me to no avail, my phone didn’t ring at all. Reboot/toggle mobile off/on solved the issue, but it’s disturbing not knowing when my phone is offline even though I’m getting a 4G with full bars.
Strange that not everyone is affected by this.
I’d be interested in seeing some logs for this (and in case of crashes: a backtrace with debugging symbols)
The easiest would probably by editing /etc/xdg/autostart/org.gnome.Calls-daemon.desktop and appending -vvv to the Exec=gnome-calls --daemon line.
Then once the endless ringing happens have a look at the journal (journalctl).
Post any findings here or ideally file an issue on the bugtracker.
This would allow me to understand what’s wrong and provide a fix swiftly
Same problem, the ringing of the phone does not stop except to reopen the “call” application if possible and kill it or turn off the phone.
And if I manage to pick up the caller hears the ringing.
In short, the phone function is unusable.
For information I am in France
@evangelos.tzaras where I find “journalctl”
Just type it in the terminal.
So I did get another incoming call from my contact list and I was able to pick up the call normally, without the constant ringing. The ringing stopped when I answered. So, the constant ringing problem appears to be intermittent, for me.
journalctl
> -- Journal begins at Wed 2022-12-14 13:47:26 CET, ends at Tue 2022-12-27 16:09:23 CET. --
> déc. 14 13:47:26 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
> déc. 14 13:47:27 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
> déc. 14 13:47:28 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
> déc. 14 13:47:29 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
> déc. 14 13:47:30 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
> lines 1-25
Test done by calling me with my landline phone and not picking up the call, it went to the answering machine but the ringing continued to ring slowing down the device enormously because it was very difficult to retrieve the information in ssh.
There is no way to go directly to the latest information because the newspaper starts on December 14.
I made
journalctl -p err
-- Boot c9d04fff9daf4c1996ffd9ed14035411 --
déc. 26 17:11:46 pureos kernel: /dev/mtdblock1: Can't open blockdev
déc. 26 17:11:46 pureos kernel: F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 1th superblock
déc. 26 17:11:46 pureos kernel: F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 2th superblock
déc. 26 17:11:49 pureos systemd-udevd[396]: sda1: /usr/lib/udev/rules.d/85-librem5-storage.rules:7 Failed to write ATTR{/sys/devices/platform/soc@0/38200000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1/queue/rotational}, ignoring: No such file or directory
déc. 26 17:11:52 pureos pipewire[785]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
déc. 26 17:11:54 pureos bluetoothd[839]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
déc. 26 17:11:54 pureos bluetoothd[839]: sap-server: Operation not permitted (1)
déc. 26 17:11:54 pureos bluetoothd[839]: Failed to set mode: Failed (0x03)
déc. 26 17:11:54 pureos wpa_supplicant[673]: nl80211: Could not set interface 'p2p-dev-wlan0' UP
déc. 26 17:11:54 pureos wpa_supplicant[673]: p2p-dev-wlan0: Failed to initialize driver interface
déc. 26 17:11:56 pureos pulseaudio[786]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
déc. 26 17:11:56 pureos pulseaudio[786]: Most likely this is a bug in the ALSA driver 'snd_soc_simple_card'. Please report this issue to the ALSA developers.
déc. 26 17:11:56 pureos pulseaudio[786]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
déc. 26 17:11:59 pureos systemd-udevd[405]: sda1: /usr/lib/udev/rules.d/85-librem5-storage.rules:7 Failed to write ATTR{/sys/devices/platform/soc@0/38200000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1/queue/rotational}, ignoring: No such file or directory
déc. 26 17:13:40 pureos wpa_supplicant[673]: nl80211: Could not set interface 'p2p-dev-wlan0' UP
déc. 26 17:13:40 pureos wpa_supplicant[673]: p2p-dev-wlan0: Failed to initialize driver interface
déc. 26 17:17:01 pureos CRON[2277]: Échec de l’authentification
déc. 26 17:25:26 pureos kernel: cma: cma_alloc: reserved: alloc failed, req-size: 3206 pages, ret: -12
déc. 26 17:25:26 pureos kernel: imx7-csi 30b80000.csi: dma alloc of size 13131776 failed
déc. 26 17:25:26 pureos kernel: imx7-csi 30b80000.csi: pipeline start failed with -12
déc. 26 17:29:10 pureos kernel: tps6598x 0-003f: tps6598x_interrupt: failed to read events
déc. 26 17:29:20 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 26 17:29:57 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 26 17:33:01 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 26 17:33:01 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 17:34:53 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 26 17:34:54 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 18:01:14 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 26 18:01:15 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 18:01:17 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 26 18:01:18 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 18:17:01 pureos CRON[4507]: Échec de l’authentification
déc. 26 18:17:58 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 26 18:17:58 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 19:17:01 pureos CRON[4734]: Échec de l’authentification
déc. 26 20:05:46 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 26 20:15:53 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:16:03 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:16:13 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:16:23 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:16:33 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:16:43 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:16:53 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:17:01 pureos CRON[5200]: Échec de l’authentification
déc. 26 20:17:03 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:17:04 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:17:13 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:17:23 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:17:33 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:17:43 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:17:53 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:18:03 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 20:18:13 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 26 21:17:01 pureos CRON[5324]: Échec de l’authentification
déc. 26 22:17:01 pureos CRON[5429]: Échec de l’authentification
déc. 26 23:17:01 pureos CRON[5538]: Échec de l’authentification
déc. 27 00:17:01 pureos CRON[5677]: Échec de l’authentification
déc. 27 01:17:01 pureos CRON[6252]: Échec de l’authentification
déc. 27 02:17:01 pureos CRON[6374]: Échec de l’authentification
déc. 27 03:10:01 pureos CRON[6449]: Échec de l’authentification
déc. 27 03:17:02 pureos CRON[6495]: Échec de l’authentification
déc. 27 04:17:01 pureos CRON[6562]: Échec de l’authentification
déc. 27 05:17:01 pureos CRON[6624]: Échec de l’authentification
déc. 27 06:17:01 pureos CRON[7116]: Échec de l’authentification
déc. 27 06:25:01 pureos CRON[7127]: Échec de l’authentification
déc. 27 07:17:01 pureos CRON[7172]: Échec de l’authentification
déc. 27 08:17:01 pureos CRON[7222]: Échec de l’authentification
déc. 27 09:17:01 pureos CRON[7279]: Échec de l’authentification
déc. 27 09:28:57 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 27 10:08:33 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:08:43 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:08:53 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:09:03 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:09:13 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:09:23 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:09:33 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:09:43 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:09:53 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:17:01 pureos CRON[8785]: Échec de l’authentification
déc. 27 10:20:13 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:20:23 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:20:33 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:20:43 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 10:20:53 pureos kernel: bq25890-charger 3-006a: NTC state UNKNOWN
déc. 27 11:17:01 pureos CRON[9050]: Échec de l’authentification
déc. 27 12:17:01 pureos CRON[9205]: Échec de l’authentification
déc. 27 13:17:01 pureos CRON[9312]: Échec de l’authentification
déc. 27 14:17:01 pureos CRON[9445]: Échec de l’authentification
déc. 27 15:17:01 pureos CRON[9567]: Échec de l’authentification
déc. 27 16:06:44 pureos kernel: tps6598x 0-003f: The interrupt is masked , how did it fire ?? f0046dffbfeffff
déc. 27 16:16:55 pureos pulseaudio[786]: Doing resync
déc. 27 16:16:55 pureos pulseaudio[786]: Playback too far ahead (467), drop source 88
déc. 27 16:16:56 pureos pulseaudio[786]: Playback too far ahead (9185), drop source 1760
déc. 27 16:16:57 pureos pulseaudio[786]: ALSA woke us up to read new data from the device, but there was actually nothing to read.
déc. 27 16:16:57 pureos pulseaudio[786]: Most likely this is a bug in the ALSA driver 'snd_soc_simple_card'. Please report this issue to the ALSA developers.
déc. 27 16:16:57 pureos pulseaudio[786]: We were woken up with POLLIN set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
déc. 27 16:16:57 pureos pulseaudio[786]: Playback too far ahead (10417), drop source 2000
déc. 27 16:16:58 pureos pulseaudio[786]: Playback too far ahead (10132), drop source 1944
déc. 27 16:16:59 pureos pulseaudio[786]: Playback too far ahead (10010), drop source 1920
déc. 27 16:17:01 pureos CRON[10163]: Échec de l’authentification
déc. 27 16:19:12 pureos kernel: watchdog: watchdog0: watchdog did not stop!
-- Boot 4bdb881d0a884a9586fd06a910faeb53 --
déc. 27 16:19:27 pureos kernel: /dev/mtdblock1: Can't open blockdev
déc. 27 16:19:27 pureos kernel: F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 1th superblock
déc. 27 16:19:27 pureos kernel: F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 2th superblock
déc. 27 16:19:29 pureos systemd-udevd[389]: sda1: /usr/lib/udev/rules.d/85-librem5-storage.rules:7 Failed to write ATTR{/sys/devices/platform/soc@0/38200000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1/queue/rotational}, ignoring: No such file or directory
déc. 27 16:19:32 pureos pipewire[776]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
déc. 27 16:19:33 pureos bluetoothd[844]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
déc. 27 16:19:33 pureos bluetoothd[844]: sap-server: Operation not permitted (1)
déc. 27 16:19:33 pureos bluetoothd[844]: Failed to set mode: Failed (0x03)
déc. 27 16:19:33 pureos wpa_supplicant[663]: nl80211: Could not set interface 'p2p-dev-wlan0' UP
déc. 27 16:19:33 pureos wpa_supplicant[663]: p2p-dev-wlan0: Failed to initialize driver interface
déc. 27 16:19:40 pureos systemd-udevd[389]: sda1: /usr/lib/udev/rules.d/85-librem5-storage.rules:7 Failed to write ATTR{/sys/devices/platform/soc@0/38200000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1/queue/rotational}, ignoring: No such file or directory
déc. 27 16:31:08 pureos pulseaudio[777]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
déc. 27 16:31:08 pureos pulseaudio[777]: Most likely this is a bug in the ALSA driver 'snd_soc_simple_card'. Please report this issue to the ALSA developers.
déc. 27 16:31:08 pureos pulseaudio[777]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
déc. 27 16:31:29 pureos kernel: usb 1-1.2: Device is not authorized for usage
déc. 27 16:49:08 pureos epiphany[2477]: Unable to configure xdg-desktop-portal access in the WebKit sandbox: GApplication must have a valid ID.
déc. 27 16:51:34 pureos kernel: watchdog: watchdog0: watchdog did not stop!
-- Boot 40882b7cc3be4873939c563d28e55ade --
déc. 27 16:51:49 pureos kernel: /dev/mtdblock1: Can't open blockdev
déc. 27 16:51:49 pureos kernel: F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 1th superblock
déc. 27 16:51:49 pureos kernel: F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 2th superblock
déc. 27 16:51:52 pureos systemd-udevd[387]: sda1: /usr/lib/udev/rules.d/85-librem5-storage.rules:7 Failed to write ATTR{/sys/devices/platform/soc@0/38200000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1/queue/rotational}, ignoring: No such file or directory
déc. 27 16:51:55 pureos pipewire[777]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
déc. 27 16:51:56 pureos bluetoothd[833]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
déc. 27 16:51:56 pureos bluetoothd[833]: sap-server: Operation not permitted (1)
déc. 27 16:51:56 pureos bluetoothd[833]: Failed to set mode: Failed (0x03)
déc. 27 16:51:56 pureos wpa_supplicant[643]: nl80211: Could not set interface 'p2p-dev-wlan0' UP
déc. 27 16:51:56 pureos wpa_supplicant[643]: p2p-dev-wlan0: Failed to initialize driver interface
déc. 27 16:52:02 pureos systemd-udevd[1043]: sda1: /usr/lib/udev/rules.d/85-librem5-storage.rules:7 Failed to write ATTR{/sys/devices/platform/soc@0/38200000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1/queue/rotational}, ignoring: No such file or directory
déc. 27 17:17:01 pureos CRON[2447]: Échec de l’authentification
déc. 27 17:17:51 pureos kernel: watchdog: watchdog0: watchdog did not stop!
-- Boot 34d43112d2db4416bdd78c169d86fe86 --
déc. 27 17:18:06 pureos kernel: /dev/mtdblock1: Can't open blockdev
déc. 27 17:18:06 pureos kernel: F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 1th superblock
déc. 27 17:18:06 pureos kernel: F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 2th superblock
déc. 27 17:18:09 pureos systemd-udevd[401]: sda1: /usr/lib/udev/rules.d/85-librem5-storage.rules:7 Failed to write ATTR{/sys/devices/platform/soc@0/38200000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1/queue/rotational}, ignoring: No such file or directory
déc. 27 17:18:12 pureos pipewire[782]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
déc. 27 17:18:13 pureos bluetoothd[841]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
déc. 27 17:18:13 pureos bluetoothd[841]: sap-server: Operation not permitted (1)
déc. 27 17:18:13 pureos bluetoothd[841]: Failed to set mode: Failed (0x03)
déc. 27 17:18:13 pureos pulseaudio[783]: Found duplicated D-Bus path for adapter /org/bluez/hci0
déc. 27 17:18:13 pureos wpa_supplicant[577]: nl80211: Could not set interface 'p2p-dev-wlan0' UP
déc. 27 17:18:13 pureos wpa_supplicant[577]: p2p-dev-wlan0: Failed to initialize driver interface
déc. 27 17:18:19 pureos systemd-udevd[401]: sda1: /usr/lib/udev/rules.d/85-librem5-storage.rules:7 Failed to write ATTR{/sys/devices/platform/soc@0/38200000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1/queue/rotational}, ignoring: No such file or directory
déc. 27 17:22:36 pureos kernel: usb 1-1.2: Device is not authorized for usage
déc. 27 18:17:01 pureos CRON[2444]: Échec de l’authentification
lines 1257-1286/1286 (END)
I guess the problem is here, I did the test at about 16:30
journalctl --since "2022-12-27 16:00:00"
déc. 27 16:31:05 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 27 16:31:06 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 27 16:31:06 pureos ModemManager[721]: <info> [modem0/call0] call state changed: unknown -> ringing-in (incoming-new)
déc. 27 16:31:06 pureos gnome-calls[1293]: MM call '/org/freedesktop/ModemManager1/Call/0' changed state to `RINGING_IN': Appel téléphonique ent>
déc. 27 16:31:06 pureos gnome-calls[1293]: New incoming call (/org/freedesktop/ModemManager1/Call/0) from +33384483136
déc. 27 16:31:06 pureos gnome-calls[1293]: Exporting 0xffff800139e0 at /org/gnome/Calls/Call/1
déc. 27 16:31:06 pureos gnome-calls[1293]: Call `/org/freedesktop/ModemManager1/Call/0' added
déc. 27 16:31:06 pureos gnome-calls[1293]: Successfully saved new call record to database
déc. 27 16:31:07 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 27 16:31:08 pureos pulseaudio[777]: Most likely this is a bug in the ALSA driver 'snd_soc_simple_card'. Please report this issue to the ALS>
déc. 27 16:31:08 pureos pulseaudio[777]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value <>
déc. 27 16:31:08 pureos phosh[1886]: The XKEYBOARD keymap compiler (xkbcomp) reports:
déc. 27 16:31:08 pureos phosh[1886]: > Warning: Unsupported maximum keycode 569, clipping.
déc. 27 16:31:08 pureos phosh[1886]: > X11 cannot support keycodes above 255.
déc. 27 16:31:09 pureos phosh[1886]: Errors from xkbcomp are not fatal to the X server
déc. 27 16:31:09 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 27 16:31:09 pureos gnome-calls[1293]: Request 'ringing' timed out, cancelling..
déc. 27 16:31:09 pureos gnome-calls[1293]: Setting ring state to 'error'
déc. 27 16:31:09 pureos gsd-color[1092]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
déc. 27 16:31:09 pureos gnome-calls[1293]: Feedback 'phone-incoming-call' triggered unsuccessfully
déc. 27 16:31:09 pureos gnome-calls[1293]: Feedback has been cancelled
déc. 27 16:31:09 pureos gsd-xsettings[1104]: Failed to get current UI legacy scaling factor
déc. 27 16:31:10 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 27 16:31:12 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 27 16:31:13 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
I confirm that I get the constant ringing issue sometimes as well. I did not report it yet, because more often I can normally pick up the phone and the ringing stops. I think the unstoppable ringing also happens sometimes for contacts that I have in my address book. As a guess: maybe it is related to not picking up the phone when a contact calls the first time, but when the contact is calling immediately for a second or later time. Maybe here is a kind of timing, or phone/call/modem state issue.
I was also thinking it might be related to callers in my contacts because the constant ringing didn’t start for me until i started syncing my contacts with nextcloud.
I use Nexctcloud too
New problem.
Calling in my contacts (my mother)
Call picked up.
Phone rings continuously throughout the call
I removed the redundant data: pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
-- Journal begins at Wed 2022-12-14 20:58:29 CET, ends at Wed 2022-12-28 18:27:02 CET. --
déc. 28 17:55:00 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:55:01 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-47 noise=9999 txrate=6000
déc. 28 17:55:02 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:55:57 pureos ModemManager[722]: <info> [modem1/call0] call state changed: unknown -> ringing-in (incoming-new)
déc. 28 17:55:57 pureos gnome-calls[1267]: MM call '/org/freedesktop/ModemManager1/Call/0' changed state to `RINGING_IN': Appel téléphonique entrant
déc. 28 17:55:57 pureos gnome-calls[1267]: New incoming call (/org/freedesktop/ModemManager1/Call/0) from +33677520000
déc. 28 17:55:57 pureos gnome-calls[1267]: Exporting 0xffff8c09a2a0 at /org/gnome/Calls/Call/1
déc. 28 17:55:57 pureos gnome-calls[1267]: Call `/org/freedesktop/ModemManager1/Call/0' added
déc. 28 17:55:57 pureos gnome-calls[1267]: Successfully saved new call record to database
déc. 28 17:55:57 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:55:59 pureos phosh[2689]: The XKEYBOARD keymap compiler (xkbcomp) reports:
déc. 28 17:55:59 pureos phosh[2689]: > Warning: Unsupported maximum keycode 569, clipping.
déc. 28 17:55:59 pureos phosh[2689]: > X11 cannot support keycodes above 255.
déc. 28 17:55:59 pureos phosh[2689]: Errors from xkbcomp are not fatal to the X server
déc. 28 17:55:59 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:55:59 pureos gsd-xsettings[1095]: Failed to get current UI legacy scaling factor
déc. 28 17:55:59 pureos gsd-color[1079]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
déc. 28 17:55:59 pureos gnome-calls[1267]: Request 'ringing' timed out, cancelling..
déc. 28 17:55:59 pureos gnome-calls[1267]: Setting ring state to 'error'
déc. 28 17:55:59 pureos gnome-calls[1267]: Feedback 'phone-incoming-call' triggered unsuccessfully
déc. 28 17:55:59 pureos gnome-calls[1267]: Feedback has been cancelled
déc. 28 17:55:59 pureos phosh[972]: Failed to load icon: Erreur lors de l’ouverture du fichier /home/purism : est un dossier
déc. 28 17:56:00 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:06 pureos kernel: bq25890-charger 3-006a: Upstream supply changed: 0.
déc. 28 17:56:06 pureos kernel: bq25890-charger 3-006a: Disabling OTG_EN pin
déc. 28 17:56:07 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:07 pureos kernel: bq25890-charger 3-006a: Upstream supply changed: 0.
déc. 28 17:56:07 pureos kernel: bq25890-charger 3-006a: Disabling OTG_EN pin
déc. 28 17:56:10 pureos ModemManager[722]: <info> [modem1/call0] user request to accept call
déc. 28 17:56:10 pureos ModemManager[722]: <info> [modem1/call0] call is accepted
déc. 28 17:56:10 pureos ModemManager[722]: <info> [modem1/call0] call state changed: ringing-in -> active (accepted)
déc. 28 17:56:10 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:10 pureos gnome-calls[1267]: MM call '/org/freedesktop/ModemManager1/Call/0' changed state to `ACTIVE': Appel décroché
déc. 28 17:56:10 pureos gnome-calls[1267]: Can't ring because we're in an error state
déc. 28 17:56:10 pureos gnome-calls[1267]: Call state changed from 5 to 1
déc. 28 17:56:10 pureos gnome-calls[1267]: Stamping call `answered'
déc. 28 17:56:10 pureos pulseaudio[782]: Configured maximum latency is smaller than latency, using latency instead
déc. 28 17:56:10 pureos pulseaudio[782]: Cannot set requested sink latency of 66,67 ms, adjusting to 32,00 ms
déc. 28 17:56:10 pureos pulseaudio[782]: Cannot set requested source latency of 66,67 ms, adjusting to 32,00 ms
déc. 28 17:56:10 pureos gnome-calls[1267]: Successfully updated call record in database
déc. 28 17:56:10 pureos pulseaudio[782]: Doing resync
déc. 28 17:56:10 pureos pulseaudio[782]: Playback after capture (-13770), drop sink 5360
déc. 28 17:56:10 pureos pulseaudio[782]: ALSA woke us up to read new data from the device, but there was actually nothing to read.
déc. 28 17:56:10 pureos pulseaudio[782]: Most likely this is a bug in the ALSA driver 'snd_soc_simple_card'. Please report this issue to the ALSA developers.
déc. 28 17:56:10 pureos pulseaudio[782]: We were woken up with POLLIN set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
déc. 28 17:56:10 pureos pulseaudio[782]: Playback too far ahead (337), drop source 64
déc. 28 17:56:11 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:11 pureos pulseaudio[782]: Playback too far ahead (5563), drop source 1068
déc. 28 17:56:12 pureos pulseaudio[782]: Playback too far ahead (30109), drop source 5780
déc. 28 17:56:13 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:13 pureos pulseaudio[782]: Playback too far ahead (11792), drop source 2264
déc. 28 17:56:14 pureos pulseaudio[782]: Playback too far ahead (11851), drop source 2272
déc. 28 17:56:14 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:15 pureos pulseaudio[782]: Playback too far ahead (11106), drop source 2132
déc. 28 17:56:15 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:16 pureos pulseaudio[782]: Playback too far ahead (10101), drop source 1936
déc. 28 17:56:17 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:17 pureos pulseaudio[782]: Playback too far ahead (8923), drop source 1712
déc. 28 17:56:18 pureos pulseaudio[782]: Playback too far ahead (8075), drop source 1548
déc. 28 17:56:18 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:19 pureos pulseaudio[782]: Playback too far ahead (7429), drop source 1424
déc. 28 17:56:20 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:20 pureos pulseaudio[782]: Playback too far ahead (6257), drop source 1200
déc. 28 17:56:21 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:21 pureos pulseaudio[782]: Playback too far ahead (6968), drop source 1336
déc. 28 17:56:22 pureos pulseaudio[782]: Playback too far ahead (9746), drop source 1868
déc. 28 17:56:23 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:23 pureos pulseaudio[782]: Playback too far ahead (10277), drop source 1972
déc. 28 17:56:24 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:24 pureos pulseaudio[782]: Playback too far ahead (9732), drop source 1868
déc. 28 17:56:25 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:25 pureos pulseaudio[782]: Playback too far ahead (10002), drop source 1920
déc. 28 17:56:27 pureos pulseaudio[782]: Playback after capture (-112), drop sink 120
déc. 28 17:56:27 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:53 pureos kernel: edt_ft5x06 2-0038: Unable to fetch data, error: -6
déc. 28 17:56:53 pureos gsd-xsettings[1095]: Failed to get current UI legacy scaling factor
déc. 28 17:56:53 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:56:53 pureos gsd-color[1079]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
déc. 28 17:56:54 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:02 pureos systemd-logind[633]: Power key pressed.
déc. 28 17:57:02 pureos gsd-xsettings[1095]: Failed to get current UI legacy scaling factor
déc. 28 17:57:02 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:02 pureos gsd-color[1079]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
déc. 28 17:57:02 pureos phosh[2731]: The XKEYBOARD keymap compiler (xkbcomp) reports:
déc. 28 17:57:02 pureos phosh[2731]: > Warning: Unsupported maximum keycode 569, clipping.
déc. 28 17:57:02 pureos phosh[2731]: > X11 cannot support keycodes above 255.
déc. 28 17:57:02 pureos phosh[2731]: Errors from xkbcomp are not fatal to the X server
déc. 28 17:57:02 pureos pulseaudio[782]: Playback after capture (-131), drop sink 128
déc. 28 17:57:03 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:03 pureos ModemManager[722]: <info> [modem1/call0] call state changed: active -> terminated (unknown)
déc. 28 17:57:03 pureos gnome-calls[1267]: MM call '/org/freedesktop/ModemManager1/Call/0' changed state to `TERMINATED': Raison inconnue
déc. 28 17:57:03 pureos gnome-calls[1267]: Can't ring because we're in an error state
déc. 28 17:57:03 pureos gnome-calls[1267]: Call state changed from 1 to 7
déc. 28 17:57:03 pureos gnome-calls[1267]: Stamping call `end'
déc. 28 17:57:03 pureos gnome-calls[1267]: Successfully updated call record in database
déc. 28 17:57:03 pureos gnome-calls[1267]: Removing call `/org/freedesktop/ModemManager1/Call/0'
déc. 28 17:57:03 pureos gnome-calls[1267]: Removed call `/org/freedesktop/ModemManager1/Call/0'
déc. 28 17:57:06 pureos gnome-calls[1267]: Call 0xffff8c09a2a0 removed
déc. 28 17:57:06 pureos gnome-calls[1267]: Can't ring because we're in an error state
déc. 28 17:57:06 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:06 pureos gnome-calls[1267]: Hung up on all calls
déc. 28 17:57:07 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:11 pureos gsd-xsettings[1095]: Failed to get current UI legacy scaling factor
déc. 28 17:57:11 pureos gsd-color[1079]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
déc. 28 17:57:12 pureos wpa_supplicant[655]: wlan0: SME: Trying to authenticate with 44:d4:54:35:a9:80 (SSID='auberge-priver' freq=5560 MHz)
déc. 28 17:57:12 pureos systemd-networkd[386]: wlan0: Lost carrier
déc. 28 17:57:12 pureos kernel: wlan0: disconnect from AP b8:be:f4:c7:51:94 for new auth to 44:d4:54:35:a9:80
déc. 28 17:57:12 pureos kernel: redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
déc. 28 17:57:12 pureos kernel: redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates....
déc. 28 17:57:12 pureos kernel: wlan0: authenticate with 44:d4:54:35:a9:80
déc. 28 17:57:12 pureos kernel: wlan0: send auth to 44:d4:54:35:a9:80 (try 1/3)
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.1674] device (wlan0): supplicant interface state: completed -> authenticating
déc. 28 17:57:12 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.1675] device (p2p-dev-wlan0): supplicant management interface state: completed -> authenticating
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.1707] device (wlan0): DHCPv4 lease renewal requested
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.1937] dhcp4 (wlan0): canceled DHCP transaction
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.1938] dhcp4 (wlan0): state changed bound -> terminated
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.1952] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
déc. 28 17:57:12 pureos kernel: wlan0: send auth to 44:d4:54:35:a9:80 (try 2/3)
déc. 28 17:57:12 pureos kernel: wlan0: send auth to 44:d4:54:35:a9:80 (try 3/3)
déc. 28 17:57:12 pureos kernel: wlan0: authentication with 44:d4:54:35:a9:80 timed out
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.8133] device (wlan0): supplicant interface state: authenticating -> disconnected
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.8134] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> disconnected
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.9152] device (wlan0): supplicant interface state: disconnected -> scanning
déc. 28 17:57:12 pureos NetworkManager[619]: <info> [1672246632.9154] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
déc. 28 17:57:13 pureos wpa_supplicant[655]: wlan0: SME: Trying to authenticate with b8:be:f4:c7:51:94 (SSID='auberge-priver' freq=5180 MHz)
déc. 28 17:57:13 pureos kernel: wlan0: authenticate with b8:be:f4:c7:51:94
déc. 28 17:57:13 pureos kernel: wlan0: send auth to b8:be:f4:c7:51:94 (try 1/3)
déc. 28 17:57:13 pureos NetworkManager[619]: <info> [1672246633.2094] device (wlan0): supplicant interface state: scanning -> authenticating
déc. 28 17:57:13 pureos NetworkManager[619]: <info> [1672246633.2096] device (p2p-dev-wlan0): supplicant management interface state: scanning -> authenticating
déc. 28 17:57:13 pureos wpa_supplicant[655]: wlan0: Trying to associate with b8:be:f4:c7:51:94 (SSID='auberge-priver' freq=5180 MHz)
déc. 28 17:57:13 pureos NetworkManager[619]: <info> [1672246633.2651] device (wlan0): supplicant interface state: authenticating -> associating
déc. 28 17:57:13 pureos kernel: wlan0: authenticated
déc. 28 17:57:13 pureos kernel: wlan0: associate with b8:be:f4:c7:51:94 (try 1/3)
déc. 28 17:57:13 pureos NetworkManager[619]: <info> [1672246633.2652] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
déc. 28 17:57:13 pureos kernel: wlan0: RX AssocResp from b8:be:f4:c7:51:94 (capab=0x1511 status=30 aid=50)
déc. 28 17:57:13 pureos kernel: wlan0: b8:be:f4:c7:51:94 rejected association temporarily; comeback duration 998 TU (1021 ms)
déc. 28 17:57:13 pureos gsd-xsettings[1095]: Failed to get current UI legacy scaling factor
déc. 28 17:57:13 pureos gsd-color[1079]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
déc. 28 17:57:14 pureos kernel: wlan0: associate with b8:be:f4:c7:51:94 (try 2/3)
déc. 28 17:57:14 pureos kernel: wlan0: deauthenticated from b8:be:f4:c7:51:94 while associating (Reason: 6=CLASS2_FRAME_FROM_NONAUTH_STA)
déc. 28 17:57:14 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-DISCONNECTED bssid=b8:be:f4:c7:51:94 reason=6
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.3829] device (wlan0): supplicant interface state: associating -> disconnected
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.3831] device (p2p-dev-wlan0): supplicant management interface state: associating -> disconnected
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.4837] device (wlan0): supplicant interface state: disconnected -> scanning
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.4838] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
déc. 28 17:57:14 pureos wpa_supplicant[655]: wlan0: SME: Trying to authenticate with b8:be:f4:c7:51:93 (SSID='auberge-priver' freq=2437 MHz)
déc. 28 17:57:14 pureos kernel: wlan0: authenticate with b8:be:f4:c7:51:93
déc. 28 17:57:14 pureos kernel: wlan0: send auth to b8:be:f4:c7:51:93 (try 1/3)
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.6351] device (wlan0): supplicant interface state: scanning -> authenticating
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.6353] device (p2p-dev-wlan0): supplicant management interface state: scanning -> authenticating
déc. 28 17:57:14 pureos wpa_supplicant[655]: wlan0: Trying to associate with b8:be:f4:c7:51:93 (SSID='auberge-priver' freq=2437 MHz)
déc. 28 17:57:14 pureos kernel: wlan0: send auth to b8:be:f4:c7:51:93 (try 2/3)
déc. 28 17:57:14 pureos kernel: wlan0: authenticated
déc. 28 17:57:14 pureos kernel: wlan0: associate with b8:be:f4:c7:51:93 (try 1/3)
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8346] device (wlan0): supplicant interface state: authenticating -> associating
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8347] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
déc. 28 17:57:14 pureos wpa_supplicant[655]: wlan0: Associated with b8:be:f4:c7:51:93
déc. 28 17:57:14 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
déc. 28 17:57:14 pureos kernel: wlan0: RX AssocResp from b8:be:f4:c7:51:93 (capab=0x1431 status=0 aid=2)
déc. 28 17:57:14 pureos kernel: wlan0: associated
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8545] device (wlan0): supplicant interface state: associating -> associated
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8546] device (p2p-dev-wlan0): supplicant management interface state: associating -> associated
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8547] device (wlan0): DHCPv4 lease renewal requested
déc. 28 17:57:14 pureos kernel: redpine_91x: EAPOL 4 confirm
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8896] dhcp4 (wlan0): canceled DHCP transaction
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8898] dhcp4 (wlan0): state changed unknown -> terminated
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8911] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8931] device (wlan0): supplicant interface state: associated -> 4way_handshake
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.8932] device (p2p-dev-wlan0): supplicant management interface state: associated -> 4way_handshake
déc. 28 17:57:14 pureos wpa_supplicant[655]: wlan0: WPA: Key negotiation completed with b8:be:f4:c7:51:93 [PTK=CCMP GTK=CCMP]
déc. 28 17:57:14 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-CONNECTED - Connection to b8:be:f4:c7:51:93 completed [id=0 id_str=]
déc. 28 17:57:14 pureos systemd-networkd[386]: wlan0: Gained carrier
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.9347] device (wlan0): supplicant interface state: 4way_handshake -> completed
déc. 28 17:57:14 pureos NetworkManager[619]: <info> [1672246634.9359] device (p2p-dev-wlan0): supplicant management interface state: 4way_handshake -> completed
déc. 28 17:57:14 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:15 pureos gnome-calls[1267]: Application not marked as daemon
déc. 28 17:57:15 pureos gnome-calls[1267]: Activated
déc. 28 17:57:15 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:16 pureos dbus-daemon[788]: [session uid=1000 pid=788] Activating service name='org.gnome.Contacts' requested by ':1.100' (uid=1000 pid=2739 comm="gnome-calls ")
déc. 28 17:57:16 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:16 pureos dbus-daemon[788]: [session uid=1000 pid=788] Successfully activated service 'org.gnome.Contacts'
déc. 28 17:57:16 pureos NetworkManager[619]: <info> [1672246636.9323] dhcp4 (wlan0): state changed unknown -> bound, address=192.168.1.12
déc. 28 17:57:16 pureos dbus-daemon[618]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.11' (uid=0 pid=619 comm="/usr/sbin/NetworkManager --no-daemon>
déc. 28 17:57:16 pureos systemd[1]: Starting Network Manager Script Dispatcher Service...
déc. 28 17:57:17 pureos dbus-daemon[618]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
déc. 28 17:57:17 pureos systemd[1]: Started Network Manager Script Dispatcher Service.
déc. 28 17:57:17 pureos gnome-calls[1267]: Cannot add contacts
déc. 28 17:57:17 pureos feedbackd[990]: Failed to erase vibra effect with id 1: Invalid argument
déc. 28 17:57:17 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:17 pureos org.gnome.Calls-daemon.desktop[2782]: Increasing verbosity to 3
déc. 28 17:57:17 pureos gnome-calls[2782]: Setting country code to FR
déc. 28 17:57:17 pureos gnome-calls[2782]: Enabling the use of default origins
déc. 28 17:57:17 pureos gnome-calls[2782]: Scanning for plugins in `/usr/lib/aarch64-linux-gnu/calls/plugins/provider'
déc. 28 17:57:17 pureos gnome-calls[2782]: Registering at /org/gnome/Calls
déc. 28 17:57:18 pureos gnome-calls[2782]: Loaded plugin `mm'
déc. 28 17:57:18 pureos gnome-calls[2782]: Watching for ModemManager
déc. 28 17:57:18 pureos gnome-calls[2782]: Created provider from plugin `mm'
déc. 28 17:57:18 pureos gnome-calls[2782]: origins changed: pos=0 rem=0 added=0 total=0
déc. 28 17:57:18 pureos gnome-calls[2782]: Loaded plugin `sip'
déc. 28 17:57:18 pureos org.gnome.Calls-daemon.desktop[2782]: su_source_port_create() returns 0xaaaaf743e220
déc. 28 17:57:18 pureos gnome-calls[2782]: Error loading key file: Aucun fichier ou dossier de ce type
déc. 28 17:57:18 pureos gnome-calls[2782]: Created provider from plugin `sip'
déc. 28 17:57:18 pureos gnome-calls[2782]: Application marked as daemon
déc. 28 17:57:18 pureos gnome-calls[2782]: Activated
déc. 28 17:57:18 pureos gnome-calls[2782]: Opening call record database using URI `file:/home/purism/.local/share/calls/records.db'
déc. 28 17:57:18 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:18 pureos gnome-calls[2782]: Numeric input enabled
déc. 28 17:57:18 pureos gnome-calls[2782]: Successfully opened call record database `/home/purism/.local/share/calls/records.db'
déc. 28 17:57:18 pureos gnome-calls[2782]: Attempting migration of call record database `/home/purism/.local/share/calls/records.db'
déc. 28 17:57:18 pureos gnome-calls[2782]: Cannot add contacts
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager appeared on D-Bus
déc. 28 17:57:18 pureos gnome-calls[2782]: Can add contacts
déc. 28 17:57:18 pureos gnome-calls[2782]: Successfully migrated call record database `/home/purism/.local/share/calls/records.db'
déc. 28 17:57:18 pureos gnome-calls[2782]: Finding records in call record database `/home/purism/.local/share/calls/records.db'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Firmware' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Modem3gpp.ProfileManager' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Modem3gpp' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Simple' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Time' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Voice' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: Adding new voice-capable modem `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: origins changed: pos=0 rem=0 added=1 total=1
déc. 28 17:57:18 pureos gnome-calls[2782]: before adding: 0
déc. 28 17:57:18 pureos gnome-calls[2782]: Adding origin 0 (0xaaaaf7813e30)
déc. 28 17:57:18 pureos gnome-calls[2782]: after adding: 1
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Messaging' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Modem3gpp.Ussd' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Signal' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: ModemManager interface `org.freedesktop.ModemManager1.Modem.Location' found on object `/org/freedesktop/ModemManager1/Modem/1'
déc. 28 17:57:18 pureos gnome-calls[2782]: Found 267 call records in database `/home/purism/.local/share/calls/records.db', fetching
déc. 28 17:57:18 pureos gnome-calls[2782]: Setting the country code to `FR'
déc. 28 17:57:18 pureos gnome-calls[2782]: Setting country code to FR
déc. 28 17:57:18 pureos gnome-calls[2782]: Fetched 267 call records from database `/home/purism/.local/share/calls/records.db'
déc. 28 17:57:19 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:27 pureos systemd[1]: NetworkManager-dispatcher.service: Succeeded.
déc. 28 17:57:27 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:34 pureos gsd-xsettings[1095]: Failed to get current UI legacy scaling factor
déc. 28 17:57:34 pureos gsd-color[1079]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
déc. 28 17:57:34 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:36 pureos kernel: bq25890-charger 3-006a: Upstream supply changed: 1.
déc. 28 17:57:36 pureos kernel: bq25890-charger 3-006a: Disabling OTG_EN pin
déc. 28 17:57:36 pureos gsd-xsettings[1095]: Failed to get current UI legacy scaling factor
déc. 28 17:57:36 pureos gsd-color[1079]: unable to get EDID for xrandr-DSI-1: unable to get EDID for output
déc. 28 17:57:36 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:37 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:40 pureos systemd-networkd[386]: wlan0: Lost carrier
déc. 28 17:57:40 pureos kernel: wlan0: disassociated from b8:be:f4:c7:51:93 (Reason: 1=UNSPECIFIED)
déc. 28 17:57:40 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:40 pureos kernel: redpine_91x: rsi_mac80211_bss_info_changed: Change of ERP INFO: 0
déc. 28 17:57:40 pureos kernel: redpine_91x: rsi_mac80211_bss_info_changed: Sending vap updates....
déc. 28 17:57:40 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-DISCONNECTED bssid=b8:be:f4:c7:51:93 reason=1
déc. 28 17:57:40 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
déc. 28 17:57:40 pureos NetworkManager[619]: <info> [1672246660.6228] device (wlan0): supplicant interface state: completed -> disconnected
déc. 28 17:57:40 pureos NetworkManager[619]: <info> [1672246660.6229] device (p2p-dev-wlan0): supplicant management interface state: completed -> disconnected
déc. 28 17:57:40 pureos kernel: redpine_91x: Antenna is changed to 3
déc. 28 17:57:40 pureos NetworkManager[619]: <info> [1672246660.7224] device (wlan0): supplicant interface state: disconnected -> scanning
déc. 28 17:57:40 pureos NetworkManager[619]: <info> [1672246660.7225] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
déc. 28 17:57:40 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
déc. 28 17:57:41 pureos wpa_supplicant[655]: wlan0: SME: Trying to authenticate with b8:be:f4:c7:51:94 (SSID='auberge-priver' freq=5180 MHz)
déc. 28 17:57:41 pureos kernel: wlan0: authenticate with b8:be:f4:c7:51:94
déc. 28 17:57:41 pureos kernel: wlan0: send auth to b8:be:f4:c7:51:94 (try 1/3)
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.1586] device (wlan0): supplicant interface state: scanning -> authenticating
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.1588] device (p2p-dev-wlan0): supplicant management interface state: scanning -> authenticating
déc. 28 17:57:41 pureos kernel: wlan0: send auth to b8:be:f4:c7:51:94 (try 2/3)
déc. 28 17:57:41 pureos kernel: wlan0: send auth to b8:be:f4:c7:51:94 (try 3/3)
déc. 28 17:57:41 pureos wpa_supplicant[655]: wlan0: Trying to associate with b8:be:f4:c7:51:94 (SSID='auberge-priver' freq=5180 MHz)
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6250] device (wlan0): supplicant interface state: authenticating -> associating
déc. 28 17:57:41 pureos kernel: wlan0: authenticated
déc. 28 17:57:41 pureos kernel: wlan0: associate with b8:be:f4:c7:51:94 (try 1/3)
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6251] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
déc. 28 17:57:41 pureos wpa_supplicant[655]: wlan0: Associated with b8:be:f4:c7:51:94
déc. 28 17:57:41 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
déc. 28 17:57:41 pureos kernel: wlan0: RX AssocResp from b8:be:f4:c7:51:94 (capab=0x1511 status=0 aid=1)
déc. 28 17:57:41 pureos kernel: wlan0: associated
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6629] device (wlan0): supplicant interface state: associating -> associated
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6630] device (p2p-dev-wlan0): supplicant management interface state: associating -> associated
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6631] device (wlan0): DHCPv4 lease renewal requested
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6817] dhcp4 (wlan0): canceled DHCP transaction
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6818] dhcp4 (wlan0): state changed bound -> terminated
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6836] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6876] device (wlan0): supplicant interface state: associated -> 4way_handshake
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.6877] device (p2p-dev-wlan0): supplicant management interface state: associated -> 4way_handshake
déc. 28 17:57:41 pureos kernel: redpine_91x: EAPOL 4 confirm
déc. 28 17:57:41 pureos wpa_supplicant[655]: wlan0: WPA: Key negotiation completed with b8:be:f4:c7:51:94 [PTK=CCMP GTK=CCMP]
déc. 28 17:57:41 pureos wpa_supplicant[655]: wlan0: CTRL-EVENT-CONNECTED - Connection to b8:be:f4:c7:51:94 completed [id=0 id_str=]
déc. 28 17:57:41 pureos systemd-networkd[386]: wlan0: Gained carrier
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.7554] device (wlan0): supplicant interface state: 4way_handshake -> completed
déc. 28 17:57:41 pureos NetworkManager[619]: <info> [1672246661.7566] device (p2p-dev-wlan0): supplicant management interface state: 4way_handshake -> completed
déc. 28 17:57:41 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:44 pureos NetworkManager[619]: <info> [1672246664.2331] dhcp4 (wlan0): state changed unknown -> bound, address=192.168.1.12
déc. 28 17:57:44 pureos dbus-daemon[618]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.11' (uid=0 pid=619 comm="/usr/sbin/NetworkManager --no-daemon>
déc. 28 17:57:44 pureos kernel: redpine_91x: Packet Dropped as Key ID not matched with both current and previous Key ID
déc. 28 17:57:44 pureos systemd[1]: Starting Network Manager Script Dispatcher Service...
déc. 28 17:57:44 pureos dbus-daemon[618]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
déc. 28 17:57:44 pureos systemd[1]: Started Network Manager Script Dispatcher Service.
I never tried to change the phone’s ring settings.
installed application that can have an action on the ringtone of the phone
- Jami
- Linphone
- Mobile Settings
- Telegram Desktop
I have similar problems with the ringing through, but only on Gnome Calls.
It’s intermittent though, I reboot the phone, make some call from contacts that did the non-stop ringing and it doesn’t do it. So not sure what’s different about a fresh reboot.
I don’t use nextcloud. But the last time my phone wouldn’t stop ringing, I had an incoming call from someone in my contacts. The caller id just showed the phone number not the persons name. When I looked in my recent calls, it just showed the number. I rebooted my phone and checked the recent call list, and the name was now showing in the missed call list. Don’t know what to make of that, but maybe it will help diagnose this problem.
Do the contact names have some non-alphanumeric character in the names? Shot in the dark.
No, Just basic names.
I created this issue for the continuous ringing.
How can I configure my L5 so that gnome-calls is always started with -vvv, see also this.
Thanks everyone for raising the issue and following up with some information.
While I could not reproduce this issue on my end it should be fixed with
this change.
You can grab and install a debian package from CI
wget https://gitlab.gnome.org/devrtz/calls/-/jobs/2484425/artifacts/raw/debian/output/gnome-calls_44~alpha.0+librem5ci476889.3132944_arm64.deb
sudo dpkg -i ./gnome-calls_44*.deb
