- Is there a way to use the stylus to move and/or resize windows? I don’t seem to be having much luck using the touchscreen to resize, and the stylus seems to do nothing on the window titlebars.
- How do I copy text that I’ve highlighted with the sytlus? Is there a stylus movement or button that does it? If I try a long press on the touchscreen, the selection is immediately cleared so there’s nothting to copy.
- The setting to move a window to the bottom of the stack is not working for me (using right button which I think is long press?). What am I missing?
- Disconnecting from the included keyboard seems to put every window back to full screen, with no option to prevent the behavior. Is there a way? I prefer to always have a multiwindow desktop, not the one-at-a-time full-screen style used on mobile phones.
Thanks and kind regards,
Dave
