Librem 11 touchscreen not registering touches well
Librem 11 touchscreen is not working right, any tips to get the touch to stop swapping to mouse input?
The L11 is running Crimson, would this be better if I switched it to Byzantium?
Byzantium is older than Crimson, so it’s very unlikely that it works better.
I think it’s occurring due to the stylus… Will try a mouse to verify that the clicking doesn’t spazz the mouse out…
Stylus is more accurate in GNOME, but also seems to work well in PHOSH, when a mouse is connected… But when using touch with finger, it seems to not be working well at all.
Have you removed the protective foil from the screen?
Yes, there is no screen protector on the screen
I installed GNOME with GDM and PHOSH both enabled, and Phosh is no longer doing the weird stuff (so far).
Still unreliable drag highlight in Files/Nautilus, but significantly better than it was… Stylus has no issues working…
