Librem 13 Charger
I’m considering buying an universal charger for a Librem 13 V4.
The actual standard is 65W.
My question is : if I use a 90W or 100W is ok or not ?
Thanks for your help on this.
Tchuss
The voltage has to be correct (and the polarity).
Hopefully the extra Watts don’t overheat your power supply.
thanks for both replies.
I’d like to buy the one from Purism directly but the delivery fees are at 50$ to EU, price of the charger itself :confused:
“ * Charger input, barrel connector, 4mm, center +19V DC, outside GND
Note
A type-C charger must be able supply at least 19V. 60W or more recommended (it may work with less but then battery can be drained even with the charger connected).”
This is from the librem 14 specs. I can’t find the specs for 13. I am expecting the 65W would work.
