When I go to the settings->sounds, where it should show a speaker, it shows headphones. When I click “test speakers” it doesn’t output to the onboard speakers.
To make matters worse, when I plug in headphones into the jack, the left side does not work unless the headphones are slightly unplugged. Because of this I suspect there’s something wrong with the headphone jack hardware in my laptop. Does anyone know where I can get a replacement part?
Thanks.
Hi,
Does the plug sits firmly in the jack or it wiggles a bit? If it wiggles it would be clear that the jack got disconnected. In this case, you could bring your laptop to a repair shop and have it soldered to the board
again. I am sorry, but this is not covered by our warranty.
It does jiggle. Thanks.
