I am sure I caused the problem when I reinstalled pureOS because I am missing a driver or something but I a having the following problems:
I am using a Dell USB-C 65 watt charger.
- Using USB-C PD does not work at all on the left side port.
- USB-C charging on the right port only maintains the battery level - the battery percentage stays where it was at (in my case right now it’s been at 49% since yesterday)
- Charging does not occur at all when the laptop is off using USB-C (The charge LED is off)
- Using the included charger, it takes about 5-6 hours to go from 20% 100%
I installed the librem-ec-acpi-dkms driver but I am still having the same problems.
