Librem-14 crash/freeze/hang
My new Librem-14 laptop LCD and HDMI screens froze.
Had to hold long-⏻ power key for hard shutdown.
Diagnostic (and other) advice appreciated!
Peace
	--Devon
P.S. MacOS saves crash data and presents it after reboot, including stack traces, active processes, etc. - does PureOS do this, and if so how can I see the latest crash data?
P.P.S. Hang coincided with Web/epiphany new-tab [+] click. Forgot to check CapsLock LED response, oops! Want the EC to watchdog the OS and blink Morse on the alarm LED when wedged.
P.P.P.S. Way too much detail follows:
# uname -a
Linux ******** 5.10.0-23-amd64 #1 SMP Debian 5.10.179-1 (2023-05-12) x86_64 GNU/Linux
# gnome-shell --version
GNOME Shell 3.38.6
# cat /etc/debian_version
buster/sid
# ~devon/bin/purism_ectool info
board: purism/librem_14
version: 1.13-devon_2023-03-22
# diff -Bbdur ~devon/{dist,hack}/Purism
Only in /home/devon/hack/Purism/librem-ec: build
Binary files /home/devon/dist/Purism/librem-ec/.git/index and /home/devon/hack/Purism/librem-ec/.git/index differ
diff -Bbdur /home/devon/dist/Purism/librem-ec/Makefile /home/devon/hack/Purism/librem-ec/Makefile
— /home/devon/dist/Purism/librem-ec/Makefile 2023-05-25 10:03:14.443239499 -0400
+++ /home/devon/hack/Purism/librem-ec/Makefile 2023-06-24 12:35:40.100333874 -0400
@@ -32,6 +32,9 @@
CFLAGS=-I$(COMMON_DIR)/include -D__FIRMWARE_VERSION__=$(VERSION)
include $(COMMON_DIR)/common.mk
+# Just a minute here - let the builder speak!
+CFLAGS+=$(EXTRA_CFLAGS)
 # Include the board's source
 BOARD_DIR=src/board/$(BOARD)
 SRC+=$(wildcard $(BOARD_DIR)/*.c)
diff -Bbdur /home/devon/dist/Purism/librem-ec/src/board/purism/librem_14/include/board/keymap.h /home/devon/hack/Purism/librem-ec/src/board/purism/librem_14/include/board/keymap.h
--- /home/devon/dist/Purism/librem-ec/src/board/purism/librem_14/include/board/keymap.h	2023-05-25 10:03:14.451239475 -0400
+++ /home/devon/hack/Purism/librem-ec/src/board/purism/librem_14/include/board/keymap.h	2023-06-24 11:38:15.884116195 -0400
@@ -53,7 +53,12 @@
 #define MATRIX_ESC_OUTPUT   10
 // Position of physical Fn key in the matrix
+#ifdef DEVON
+#define MATRIX_FN_INPUT     1
+#define MATRIX_FN_OUTPUT    3
+#else // DEVON
 #define MATRIX_FN_INPUT     2
 #define MATRIX_FN_OUTPUT    13
+#endif // DEVON
 #endif // _BOARD_KEYMAP_H
Only in /home/devon/hack/Purism/librem-ec/src/board/purism/librem_14/keymap: devon.c
# diff -Bbdur ~devon/hack/Purism/librem-ec/src/board/purism/librem_14/keymap/{default,devon}.c
--- /home/devon/hack/Purism/librem-ec/src/board/purism/librem_14/keymap/default.c	2023-05-25 10:03:14.000000000 -0400
+++ /home/devon/hack/Purism/librem-ec/src/board/purism/librem_14/keymap/devon.c	2023-06-24 19:06:38.915829593 -0400
@@ -1,26 +1,52 @@
 // SPDX-License-Identifier: GPL-3.0-only
+// librem-ec/src/board/purism/librem_14/keymap/devon.c
-// Default layout
+// Devonian layout
+// Swap CapsLock & BackSpace here, not in kmonad --
+//	kmonad-mapped CapsLock autorepeat fails in Mozilla.
+// Kmonad best customizes the key left of (tiny) RightShift --
+//	with tap/hold dual functions on the same key.
+// Swap LeftControl & Fn -- like on ThinkPads and MacBooks
+//	where the Fn key is in the lower left corner.
+// TO DO
+// Dynamic keymapping should support all such customizations --
+//	without breaking the Fn+Esc reset function.
+// Fn+F1 & Fn+F2 should do something useful.
+// Should Fn+Space duplicate Fn+F4 cycle keyboard backlight glow?
+// Solve FireFox & Thunderbird physical CapsLock autorepeat failure.
 #include <board/keymap.h>
+#ifdef DEVON
+  #define BKSP_CAPS K_CAPS
+  #define CAPS_BKSP K_BKSP
+  #define LCTRL_FN KT_FN
+  #define FN_LCTRL K_LEFT_CTRL
+#else // DEVON
+  #define BKSP_CAPS K_BKSP
+  #define CAPS_BKSP K_CAPS
+  #define LCTRL_FN K_LEFT_CTRL
+  #define FN_LCTRL KT_FN
+#endif // DEVON
 uint16_t __code KEYMAP[KM_LAY][KM_OUT][KM_IN] = {
 // regular key layout
 LAYOUT(
     K_ESC, K_F1, K_F2, K_F3, K_F4, K_F5, K_F6, K_F7, K_F8, K_F9, K_F10, K_F11, K_F12, K_PRINT_SCREEN, K_DEL,
-    K_TICK, K_1, K_2, K_3, K_4, K_5, K_6, K_7, K_8, K_9, K_0, K_MINUS, K_EQUALS, K_BKSP,
+    K_TICK, K_1, K_2, K_3, K_4, K_5, K_6, K_7, K_8, K_9, K_0, K_MINUS, K_EQUALS, BKSP_CAPS,
     K_TAB, K_Q, K_W, K_E, K_R, K_T, K_Y, K_U, K_I, K_O, K_P, K_BRACE_OPEN, K_BRACE_CLOSE, K_BACKSLASH,
-    K_CAPS, K_A, K_S, K_D, K_F, K_G, K_H, K_J, K_K, K_L, K_SEMICOLON, K_QUOTE, K_ENTER,
+    CAPS_BKSP, K_A, K_S, K_D, K_F, K_G, K_H, K_J, K_K, K_L, K_SEMICOLON, K_QUOTE, K_ENTER,
     K_LEFT_SHIFT, K_Z, K_X, K_C, K_V, K_B, K_N, K_M, K_COMMA, K_PERIOD, K_SLASH, K_UP, K_RIGHT_SHIFT,
-    K_LEFT_CTRL, KT_FN, K_LEFT_SUPER, K_LEFT_ALT, K_SPACE, K_RIGHT_ALT, K_RIGHT_CTRL, K_LEFT, K_DOWN, K_RIGHT
+    LCTRL_FN, FN_LCTRL, K_LEFT_SUPER, K_LEFT_ALT, K_SPACE, K_RIGHT_ALT, K_RIGHT_CTRL, K_LEFT, K_DOWN, K_RIGHT
 // FN+key layout
 LAYOUT(
     K_SUSPEND, K_F1, K_F2, K_DISPLAY_MODE, K_KBD_BKL, K_BRIGHTNESS_DOWN, K_BRIGHTNESS_UP, K_MEDIA_PREV, K_PLAY_PAUSE, K_MEDIA_NEXT, K_MUTE, K_VOLUME_DOWN, K_VOLUME_UP, K_PRINT_SCREEN, K_INSERT,
     K_LEFT_SHIFT, K_Z, K_X, K_C, K_V, K_B, K_N, K_M, K_COMMA, K_PERIOD, K_SLASH, K_PGUP, K_RIGHT_SHIFT,
-    K_LEFT_CTRL, KT_FN, K_LEFT_SUPER, K_LEFT_ALT, K_KBD_BKL, K_RIGHT_ALT, K_RIGHT_CTRL, K_HOME, K_PGDN, K_END
+    LCTRL_FN, FN_LCTRL, K_LEFT_SUPER, K_LEFT_ALT, K_KBD_BKL, K_RIGHT_ALT, K_RIGHT_CTRL, K_HOME, K_PGDN, K_END
+// end librem-ec/src/board/purism/librem_14/keymap/devon.c
\ No newline at end of file
I would say: new device => contact Purism Support. support@puri.sm
I contacted support - and also hope to learn from our collective wisdom.
Froze again but this time I had a process blinking the RGB LED, which kept blinking so I suspect only the GPU was wedged. I let it sit for an hour or so, found it snoring and woke it ok, suggesting Fn-Esc as a possible (but obnoxious) workaround. I now have enabled SSH and run two processes writing to the RGB LED, one cycles blue/green at 0.2 Hz, the other flashes red when I whip the mouse.
POSSIBLE WORKAROUND
Symptom - Librem-14 screens, mouse cursor, etc., crash/freeze/hang.
Tap Fn-Esc - should instantly sleep but nothing happens ## showing the system is unresponsive.
Tap Fn-F4 six times - keyboard glow backlight intensity should change ## showing the Embedded Controller (EC) responds.
Wait - long enough to launch an ssh session into the Librem-14 and type $ top -n1 ## showing Xwayland burning 100% CPU.
The fans roar. If you’re lucky, after a while the screens go black, ssh stops responding and the battery LED starts snoring ## showing that Fn-Esc eventually slept the system after all.
Tap Power to wake the sleeping system - everything seems normal until the next crash/freeze/hang which could be minutes away.
	Peace
		--Devon
P.S. Reporting these frequent crashes of a brand-new Librem-14 to Purism got advice to wait a few months for the next PureOS release. Looks like an Xwayland bug which was fixed last winter…
# apt source Xwayland
Reading package lists... Done
E: Unable to find a source package for Xwayland
# Xwayland --version
Unrecognized option: --version
# strings $(type -p Xwayland) | grep -i '\<version\>'
glamor%d: Failed to get GLSL version
glamor%d: Failed to parse GLSL version string %s
Require OpenGL version 2.1 or later.
#version 130
#version %d
Protocol version mismatch
.gnu.version
…stay tuned.
How unusual. What happens if you boot a PureOS live image on a USB drive instead? Are Coreboot and the EC firmware updated to the latest version?
Unclear whether this workaround requires Fn-Esc, lid closure, or both.
I now question closing the lid - stopping the fans risks heat damage,
a possible EC bug - better spin the fans regardless of lid closure.
On the other hand, just powering down the CPU could be safer.
Every prior hang has been preceded by a “Firefox is not responding” popup
but today’s hang also had a “Gnu Emacs Client is not responding” popup.
As usual, Fn-F4 changes keyboard glow but Fn-Esc is unresponsive.
2023v30w1119 *	lid close, wait, open, snoring, login normally but fans screaming
2023v22t1450	devon    tty2         tty2             Tue Aug 22 14:50 - crash (1+23:55)
2023v15t1947 *	lid close, wait, open, snoring, login normally
2023v07m1150 *	dies again two hours later
2023v07m0940 *	lid close, wait, open, snoring, login normally
2023v07m0928 *	lid close, wait, open, snoring, login normally
2023f25n1136	devon    tty2         tty2             Sun Jun 25 11:36 - crash (13+04:58)
2023f25n1133 *	Fn-Esc unresponsive, hold power button to force reboot
2023f24s1335	devon    tty2         tty2             Sat Jun 24 13:35 - crash  (21:59)
2023f22r2126	devon    tty2         tty2             Thu Jun 22 21:26 - crash (1+16:09)
2023e31w2215	devon    tty2         tty2             Wed May 31 22:15 - crash (6+14:16)
2023e29m2113	devon    tty2         tty2             Mon May 29 21:13 - crash (1+21:54)
* indicates manually logged system hangs, other lines from $ last | grep 'crash'
You should not be experiencing anything like this with a new Librem 14 device. It will be a while before the next PureOS version, Crimson, will be released.
Use these links as a guide to reflash the Coreboot firmware. Create a PureOS live image on a USB drive as part of the flashing process, and use it for any further debugging needs after you are done.
https://downloads.puri.sm/10/gnome/2023-06-14/
Hung again just now at 13:17:50 and Fn-Esc followed by a ten minute wait did nothing, closing the lid for five minutes got it snoring and revived. Awfully unlikely that anything in the EC or boot process would affect this well-documented, already-fixed Xwayland bug. Nothing from # apt search xwayland-dev and I have no idea how to find out what build options work for PureOS.
	Peace
		--Devon
P.S. Will try more after backup. Too bad I’m not allowed to search https://source.puri.sm.
I had to update the EC to make the 3.5 mm audio jack work. I also swapped Ctrl↔Fn and CapsLock↔Backspace, I thought I posted my keymap patch but I don’t see it.
# dmidecode --string bios-version
4.19-Purism-2
My suggestion is to flash the PureOS live image onto a USB drive. You are free to verify it with the link I provided above. Otherwise consider experimenting with different operating systems instead to ensure that your issue can be resolved elsewhere.
This just started happening to my L14. It is clearly xwayland and seems to be caused by Firefox ESR. In order to get my L14 back, I have to go onto one of my other linux machines and ssh in and kill the user with
sudo skill -KILL -u
My device is
Blockquote
Linux zzzzzzzzzz 5.10.0-28-amd64 #1 SMP Debian 5.10.209-2 (2024-01-31) x86_64 GNU/Linux
PureBoot-Release-18.1
Okay, I suggest externally backing up any important files, preparing a PureOS image on a USB drive, booting into it, reinstalling the operating system, and updating PureBoot after. If necessary, upgrading the EC firmware may help resolve any other lingering issues.
Interestingly, I replaced the battery and the problem is diminished. The machine still freezes but only for a few moments and then comes back.
Recently there have been a few occurrences where reseating the RAM has solved freezing/hanging issues, so I suggest trying it with your Librem 14.
Just an anecdote. I have been using PureOS Byzantium with mate desktop, a different browser than Firefox, and 64GB ram installed onboard, and I don’t recall ever having a problem like this. I got the device somewhere in Nov-Dec of 2023, and used it very frequently since then. (Running coreboot/SeaBIOS, not fancy Pureboot).
This question was maybe a year ago, so I hope you know by now. But obviously the answer to this question is not specific to PureOS. Maybe that’s the magic of Linux+GNU stuff, you have a big stack of similar tools that many people use in different places. So if you look up general information on systemd crash logs, you’re likely to find something relevant to PureOS.
I had too often that problem with the new pureboot 30, so after downgrading to 29 my problem (almost totally) disappeared.
