Librem 14 Crash
My Librem 14 crashed on Byzantium PureOS. This is not common for me although it happened twice this week. Here is what journal says:
Oct 02 21:32:47 myhost brltty[1522]: /lib/brltty/libbrlttyxa2.so: cannot open shared object file: No such file or directory
Oct 02 21:32:47 myhost brltty[1522]: cannot load screen driver: /lib/brltty/libbrlttyxa2.so
Oct 02 21:32:47 myhost brltty[1522]: screen driver not loadable: a2
Oct 02 21:32:47 myhost vinagre[19257]: Drawing a gadget with negative dimensions. Did you forget to allocate a size? (node box owner ViewAutoDrawer)
Oct 02 21:32:48 myhost vinagre[19257]: Drawing a gadget with negative dimensions. Did you forget to allocate a size? (node box owner ViewAutoDrawer)
Oct 02 21:32:48 myhost kernel: i915 0000:00:02.0: [drm] Resetting rcs0 for preemption time out
Oct 02 21:32:48 myhost kernel: i915 0000:00:02.0: [drm] *ERROR* rcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
Oct 02 21:32:48 myhost kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 9:1:85dffffa, in Xorg [1449]
Oct 02 21:32:52 myhost brltty[1522]: /lib/brltty/libbrlttyxa2.so: cannot open shared object file: No such file or directory
Oct 02 21:32:52 myhost brltty[1522]: cannot load screen driver: /lib/brltty/libbrlttyxa2.so
Oct 02 21:32:52 myhost brltty[1522]: screen driver not loadable: a2
Oct 02 21:32:57 myhost brltty[1522]: /lib/brltty/libbrlttyxa2.so: cannot open shared object file: No such file or directory
Oct 02 21:32:57 myhost brltty[1522]: cannot load screen driver: /lib/brltty/libbrlttyxa2.so
Oct 02 21:32:57 myhost brltty[1522]: screen driver not loadable: a2
Oct 02 21:32:57 myhost kernel: Asynchronous wait on fence 0000:00:02.0:Xorg[1449]:5d06bc timed out (hint:intel_atomic_commit_ready [i915])
Could this crash be caused by FBI interference after I made a post that Signal is compromised here? Maybe FBI thinks this is funny, and one of their guys was bored this evening and is hacking me.
Or is this a known bug in Byzantium + Xorg? Would it be fixed by Crimson?
sudo apt purge brltty && sudo sed -i 's/GRUB_CMDLINE_LINUX_DEFAULT="/GRUB_CMDLINE_LINUX_DEFAULT="i915.enable_fbc=0 i915.enable_psr=0 /' /etc/default/grub && sudo update-grub && sudo reboot
Do we know why those settings would help? I guess some bad intel optimizations? Is this because of that time a year ago I booted Windows from an external drive on the Librem 14 and maybe it got mucked up somehow?
I know you might not know, but I thought I would try asking. Thanks for your time
This is 2 solutions in 1 for possible Gpu hang, above
But you can try just uninstalling: brltty
I do not think because you used Windows, however Windows OS and Linux OS(Ubuntu,Debian,ArchLinux,Fedora,LinuxMint) are equally dangerous.
Also track if the CRASH appears after a suspension state resumen that WindowS
