Librem 14 does not boot from USB Pure OS 9
Hello
I have been testing Librem 14 and successfully installed Pure OS 10 Dev.
I have also installed latest firmware update Coreboot/Pureboot as per instructions https://puri.sm/projects/coreboot/
Now Librem 14 stuck on booting from USB with Pure OS 9 (pureos-9.0-gnome-live_20200806-amd64.hybrid.iso):
  1. Select your USB Disk: /dev/sdb1_PureOS_9.0_GNOME_Live
  2. Select your boot option: Live_system_[vmlinuz-4.19.0-9-amd64]
The error I get:
Failed to find file /vmlinuz-4.19.0-9-amd64
!!! Failed to boot w/ options: Live system|elf|kernel /vmlinuz-4.19.0-9-amd64|initrd /initrd.img-4.19.0-9-amd64|append boot=casper quiet splash
!!!! Something failed during USB boot
New value PCR[4]: XXXXXXXXXXXXX
!!!!! Starting recovery shell
I have tested the boot media to start installation on a ThinkCentre and it is working.
I think that the issue is related to Coreboot/Pureboot but there is no instructions how to downgrade. Have you got a tip?
Can someone please help what to do or is it best to contact support?
This is correct, you need PureOS 10 on the Librem Mini v2 and Librem 14.
https://downloads.puri.sm/byzantium/
Cheers
nicole
Librem 14 supports PureOS 10, Byzantium and up! Thank God for that. I have wasted hours yesterday trying to make it work! LOL
Thanks @nicole.faerber
