Librem 14 - Ethernet Port
I am aware the the Librem 14 has a different type of ethernet jack. Can somebody recommend an adapter they may be using so I can one ahead of my laptop’s arrival?
Thank you if you take the time to reply.
Librem 14 have normal ethernet conenctior, it just have hinge to cover it up when not used. no adapter needed.
Ok, thanks for that. For some reason I thought it had some other type.
Excellent.
