yes, because the values are saved in the EC’s battery-backed RAM (BRAM). As long as the internal battery isn’t disconnected, the settings will persist until overridden externally
Finally the solution provided by the support was to install the firmware using dkms
instead of make
(for non Debian distributions).
After cloning or downloading the source from the link provided by the support, follow instructions below.
Copy the Debian
dkms.conf
to the root of the source directory:cp debian/librem-ec-acpi-dkms.dkms dkms.conf
Modify
dkms.conf
in a text editor so PACKAGE_VERSION is set to a value:PACKAGE_NAME="librem_ec_acpi" PACKAGE_VERSION="1.0" BUILT_MODULE_NAME[0]="librem_ec_acpi" DEST_MODULE_LOCATION[0]="/updates/dkms" AUTOINSTALL="yes"
Add and build the module using dkms:
sudo dkms add ./ sudo dkms build librem_ec_acpi/1.0 sudo dkms install librem_ec_acpi/1.0
Now lsmod should show librem_ec_acpi:
lsmod | grep librem_ec_acpi librem_ec_acpi 16384 0
You should also see new files to control the battery:
cat /sys/class/power_supply/BAT0/charge_control_start_threshold 40 cat /sys/class/power_supply/BAT0/charge_control_end_threshold 95
Thank you @joao.azevedo
there are already some non Debian distributions that have it packaged.
- Arch and derivatives via AUR;
yay -S librem-ec-acpi-dkms
- Guix: https://guix.gnu.org/en/packages/librem-ec-acpi-linux-module-0.9.1/
And there are some instructions for QubesOS: https://source.puri.sm/-/snippets/1170
And the librem-ec-acpi
is now in Debian Experimental, so “soonish” it should start entering the DEB “world”
I had to set the start and end thresholds again after installing the latest (4.14-Purism-1) coreboot update. The start was back to 0. Is there a plan to make the user defined battery charging settings persistent over the coreboot update?
coreboot has nothing to do with the EC battery thresholds, updating coreboot would not change/clear them.
The most recent EC firmware update sets these to 90/100 as the default, so they should not reset back to 0/100 ever after applying it
@MrChromebox Thank you for the clarification. In that case I wonder what I did so these thresholds were reset. What I know I did was update coreboot with the coreboot utility script. And of course updates with apt. Could the latter have caused the reset?
if the kernel got updated, possible the EC driver did not persist across?
I do not know enough to answer that question… what I can say, is that I used the option to compile the update locally.
So, stupid question but… how would one fix this if the battery was at 10%, the laptop powered off and now barely is able to start with either a USB-C or the BJ charger?
