I have recently bought a Librem 14. I travel often and use the stock charger when I am at home and a USB-C travel charger (it matches the specs of the stock charger).
I tested the USB-C charger and it worked. Last week it started discharging, but when I put the notebook to sleep, it charged back up and thought nothing of it when I returned home and used the stock charger.
Today I was transferring files and I noticed that while on the stock charger, the battery drained to 10% and then soon shut off (not surprisingly). The power cable and charger do not seem to charge the notebook again, nor does any other suitable cable.
https://forums.puri.sm/t/new-problem-with-librem-14-not-charging-battery-solved/14023/12
https://forums.puri.sm/t/librem-14-failed-to-charge-solved/13935/53
While the above posts show a similar issue with being solved, they mentioned quite a lot of work in the console, which is ok, but I am unable to really power the Librem on for more than a few seconds. A press of the power button takes me to the prompt for the boot menu and sometimes I can get to the boot menu before it shuts off.
I am using PureOS. Any tips to resolve this issue?
