Attempt to reinstall with USB stick
Installation running
Installation completed
At this point today I was three times.
When restarting, the system freezes.
After pressing Ctrl, Alt + Del and restarting
IMG_20210605_161007|499x499
After that only a black screen with blinking cursor follows.
Regards
Martin
Have you tried installing PureOS 10?
With the delivery yesterday I received a stick with PureOS 9.
I have not tried PureOS 10 yet.
I will try it.
I don*t find the download-link
Next try PureOS 9, as I can’t find PureOS 10.
Has anyone tried to install a system encrypted via LUKS with a separate data partition?
Unfortunately I failed according to instructions
https://tracker.pureos.net/w/installation_guide/live_system_installation/
Manual partitioning
New Partition Table
GPT
Free Space --> Create --> 8 MiB File system unformatted bios-grub
Free Space --> Create --> 70000 MiB Filesystem --> linuxswap Encrypt
Free Space --> Create --> 40000 MiB Filesystem --> ext4 Encrypt --> Mointpoint /
Free Space --> Create --> 40000 MiB Filesystem --> ext4 Encrypt --> Mointpoint /home
Free Space --> Create --> Rest of Space MiB Filesystem --> ext4 Encrypt --> no Mountpoint
And then:
Installation Failed
Boost.Python error in job “bootloader”
Command ‘grub-install --target=i386-pc --recheck --force /dev/nvme0n1’ returned non-zero exit status 1.
Installing for i386-pc platform grub-install: warning: this GPT partition label contains no BIOS Boot Partition; embedding won’t be possible. grub-install: error: embedding is not possible, but this is required for RAID and LVM install.
