Librem 14 notification tool
I’ve been writing a tool for Librem 14’s notification light to enable anyone to use a GTK wrapper to set color, pattern, and behavior on a global or per-app basis. Currently the only known limitation is the librem14-led program as anything it can do is what the tool will be able to do. primalmotion/librem14-led: SImple bash script to pilot the Librem 14 notification LED - Codeberg.org
If all goes well, one can hope that it should be pluggable to Librem 16. I plan on packagibg the whole thing up when done. Not sure who to reach for getting it in Purism’s repos but I think it’d be neat.
One bug I keep running into is killing an event after logging back in doesn’t always kill the status light. Another potential but may involve suspent, but I haven’t tried that yet. Just trying to make sure everything is called and canceled properly before building the rest of it. I want a solid foundation that I can build up.
Nice! I can’t wait for someone to make a Xmas light show with music using that notification light. :wink:
Again a big limiter is it only does what is built into the capability of the Librem14-led tool. If it’s not possible with the tool by some combination of its ability, then it won’t work. But from what I’ve found you can do multicoler flashing and even time it against notifications.
