Librem 14 power-offs when audio jack is connected
Sometimes wen I plug in headphones to audio jack of L14 the screen fades off and I have to unplug charger before I can turn it on with power button again. I use mostly the original DC barrel power source, but it happens with USB-C charger also.
I have PureBoot 28.3 now (and I think it is happening since the firmware which implemented the audio jack detection). I use QubesOS, but it happened even before OS booted up, so I guess it does not depend on OS.
I think there is less chance this happens when I suspend, connect audio cable and wake up.
The audio works, including the microphone.
Has anyone same problem?
I have noticed this too sometimes, though this does not happen all of the time. I haven’t had the time to investigate reliable steps to reproduce this.
@Honza , @gondolyr - I have an idea to improve this, but it doesn’t occur on the devices I have, so I could use your help testing it. Can either of you test preview EC builds on your Librem 14? I will need a bit of time to prepare the build and test the basics, but once it’s ready it would be helpful if you are able to run it for a while to monitor for this issue.
How did it go?
If you are still waiting for testers, I volunteer.
I experienced it twice today.
So far my solution is downgrade to version before automatic audio jack detection and wait.
